DIY Flashboard Riser
/ DIY Flashboard Riser #1
pickandstick
tc40a & jd5410
I am getting ready to install a flashboard riser to regulate the water level in my duck pond. I have priced several, but they look like they should be fairly easy to fabricate. Has anyone ever built one of these? any pictures or comments would be appreciated. Thanks.
/ DIY Flashboard Riser #2
The new move in enviromental protection is to keep Cresote , and any Pressure treated wood away from water ways. I think hemlock? or doug fir or cedar or redwood are good choices.
Craig Clayton
/ DIY Flashboard Riser #3
Craig Clayton
Never gave it any thought but how about the new plastic decking?? We installed 10's of thousands of sq ft as sound barriers, so it should last a long time. Of course that'll probably be next on the toxic waste list like tires.
/ DIY Flashboard Riser #4
What is the configuration of your dam's outlet? Are you putting the board on a riser structure or on an overflow spillway? A picture of what you are modifying would help me help you.
flashboard_risers
This is what I want to build. It will go onto the upstream side of a 24" culvert.
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
2011 GREAT DANE 7211TZ 53FT T/A REFRIGERATED TRAILER (A59912)
2011 GREAT DANE...
2358 (A64281)
2358 (A64281)
1067 (A64280)
1067 (A64280)
AgCo Console 1 Monitor (A63117)
AgCo Console 1...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
