Flatbed
/ Flatbed #1
HiTechTed
Gold Member
Indiana
Kubota L3400
have any of you guys ever made your own flatbed for your pickup truck? I'm considering doing it but have little experience in that area. What I'd like to do is set it up as a dump bed as well. I have a 95 Ranger (not much of a truck, I know) but it's paid for and is very reliable, I've owned it since new and am the only one to ever drive it. I don't need to haul a lot (good thing since it's a Ranger). We get a lot of mulch every year, plus I have some dirt around here that I need to move. If I could make a flat bed for a relatively decent price, somehow make it dump and possibly bolster the suspension a little bit, it would get quite a bit of use. My idea for the flat bed would be to drop a bit of weight compared to the stock bed, in hopes of possibly bumping up the payload capacity a few hundred pounds.
All things considered, what do you guys think? Have any of you done anything similar?
/ Flatbed #2
Quite a few years ago you would see a lot of pickups around here with them, not so much now. I had one on an old ford pickup that the box rusted out. In the summer it was the greatest using around the farm, easy to reach anything in the bed, great for carrying. In the winter I really regretted it since the truck was so light weight with it. I ended up driving all winter with a round bale sitting on it. As far as dumping them all I can suggest to be ultra cheap would be to check into those hydraulic systems for swinging up the cad on a flat nose cabover hyway tractor to see it they are capable. You could dump it using a hand pump then.
/ Flatbed #3
I've actually been thinking of building me a flat bed for my 1992 Chevy Pickup. It's got a regular narrow bed on it as of now and I can hardly fit anything in it.
The beds more for looks than for hauling. I'd rather be able to haul something not just look at it.
If I made a flat bed for it. I would make some side boards incase I needed an enclosed bed to haul something in.
Chad
edit: My dad keeps trying to talk me out of it saying the value of the truck is more with the sporty looking bed on it. I say I don't care. I'm not selling it anyway. My dad gave it to me for my 16th Birthday.
And I'm gonna drive that truck until it won't go any further. Then when it retires I will put it up on blocks as a yard decoration. :laughing:
/ Flatbed #4
I have built several over the years. Unless you plan on using aluminum I don't know how in the world you'll build a flatbed dump lighter than the factory bed. This one for an F-550 ended up being right at 1-ton.:laughing:
/ Flatbed
It probably won't happen, at least not with this truck. I just wanted to use it since I own it and it's a good truck, but it's just not really the right truck to do anything like this with. I suppose there would be a way to take the stock bed and make it a dump bed. No gain in payload but a lot better than shoveling stuff out of the bed!
/ Flatbed #8
well if your looking for a project it would be fun to build. take the existing box off and get rid of it. Remembering that you will not have a huge capacity build accordingly. I would start with a good solid pivot point then build a light frame and use plywood for a deck. 3/4in plywood tek screwed to light tubing makes a very strong surface. If you build sides in your design that will give you much needed strength without need so heavy material on the frame.
this is very quick drawing to maybe give you an idea where I am coming from. it would probably make your little truck a bit more useful for those tasks. Even if you can actually dump stuff right out getting a nice slope is huge for shoveling off a deck.
/ Flatbed #9
HiTachTed, It's a cool idea and I agree with ShielArc. It's going to be heavy, even before the hydraulics. I've built a couple of Pipe welding rigs and the beds for those were really heavy. Even before all of the equipment on it. I think my question would be, can the stock frame take that kind of load. The stock frame may need to be boxed to some degree??? Nothings impossible, the realization of it just takes a little longer. Keep us posted. I love things that are paid for when there done!!
/ Flatbed
Yeah, I've seen those and they deserve a big :laughing: I could hook up a gas engine to the crank and make it a powered loadhandler...LOL
Now for the hoist kits, those are cool but I have never seen one made for a small truck like a Ranger. The reason for that is probably the 1260lb payload capacity of all Rangers (from what I've gathered researching). Take my 230lbs off of that and I'm down to 1030lbs with everything stock.
Regneufeld has a good idea, the lighter the better. Really if I could convert the Ranger over and get 1000lbs in it AND make it dump, I would be totally happy with that. I ask questions about things like this online because it's easier to get laughed at this way ":laughing:" than face-to-face with a guy who asks why on Earth I'd even consider using a Ranger....
So, how could I reinforce things and possibly bump up the suspension a hair, in the least expensive way(s) possible?
/ Flatbed #11
well for what you say your going to use it for, if it was me I would build the deck with the hinge points using a small 12v winch to lift it. Then I would look at either incorporating some type of rubber bump stops so if it was to much load it would bottom out on the rubbers. Then your suspension becomes your tires more or less.
Vehicle Suspension Kits - Timbren Suspension Enhancement Systems these would be a good solution but did not look if they had ones ranger specific. I would be pretty confident I could build a deck as light as a stock box that would handle the weight issues you would be safe to use on a small truck like that.
I built a similar box on a old tent trailer, chucked all the old sheet metal on the outside and built a light frame and used 1/2 plywood screwed to the sides. It was not heavy but would hold much more then the axle would dream of holding. In hindsight on that one I should have narrowed the trailer deck way down, but it makes a great garbage trailer at my brothers cabin. It is just when people think you can fill it full of firewood it becomes a problem
/ Flatbed #12
I would look into one of the lifts that use an air bag. You can buid the flat bed or use the stock bed. The bag lift kit comes with cross stablelizers for the frame. It could probably be modidied to fit another truck should you decide to change.
/ Flatbed #13
I have made 2 flatbeds in the past (85 F150 and 04 F350) but they do not dump. The are made with steel and the decking is pressure treated 2x6 lumber. I made some removable sides, the second one I built i can make a full or 3 feet long box if i want to. They are simple to make and lighter than a regular box, you might look like a hillbilly but so much more usefull. I can post pictures if anybody wants to see it.
/ Flatbed
Sure, pics are always good!
/ Flatbed #15
I too have built several flatbeds, some with hoists, others without. As you are building for a Ranger, it doesn't have to be built with heavy material.
I would take some 2x2 square tube for the two long runs on the frame. Use about 6, 3 on either side of 2x2x3/8 flatbar from the 2x2 down and bolt to the frame on the sides, not the flanges. Use 2inch angle iron for cross pieces. I/8in should be heavy enough. on the outside I like to use 2x4x1/8th tubing for stake pockets. They let you use a 2x4 for stakes. By tying the 2x4 into the crosspieces and to the outside piece that runs the length of the bed like a 1/4x3in flatbar, it ties up the sides and crossmembers really well. Making a headboard is just a matter of tying it into the front of the bed.
If you want to put a hoist in, I would get the one you want before starting this project as you will need to know clearances in your frame and height between frames.
This bed is of course a lot more than you need, but if you look close it will give you an idea of how the stakes tie in the crossmembers and the outside rail.
When putting the pockets in, take care to think of the thickness of the material of the deck so you can adjust the height of the pockets on the crossmembers so they will be flush with the finished deck.
Have fun
/ Flatbed #16
Carbon fiber pre preg wrapped around blue foam. Vacuum bagged and autoclaved will be stronger than steel. You could do it cold too with CF cloth and epoxy resin. If you set it up the right way, and use a slow hardener, you should be able to do the whole tray/substructure in one shot. If you use regular glass, then make it a little thicker. the vacuum bagging is key though.
/ Flatbed #17
I'd build a flatbed, and forget the dump. Can't have it all. Not on a lite truck like that.
/ Flatbed #18
Ive built some too, in a previous occupation.
I'd say, 4" cold rolled C channel as longitudinal members, as well as edge profiles. 2 1/2" crossmembers. Both should not exceed 3mm wall thickness (sorry dont know what that is in inch, or gauge)
Then cover it with a sheet of 3/4" (18mm) plastified plywood. We built a bunch of those beds.
If you want to be able to dump, you need 4 or 5mm thickness of the longitudinal members, and a subframe on the truck frame to distribute the forces. Then you'll end up with a payload of two wheelbarrows of dirt: It would be easier and cheaper to just strap the two filled wheelbarrows to the bed and dump them off by hand.. ;)
/ Flatbed #19
i've seen a bunch of homemade flatbeds, even on smaller trucks, though most of them are not the best designed or built. the one thing you are going to be fighting is weight. you certainly don't want to overbuild it, or your truck's carrying capacity will be limited to a 50lb bag of potatoes.
i prefer channels to tubes, but only because of the salt and corrosion here. otherwise tubes are nicer to work with. for something like this, i would use nothing larger than a c3x4.1 for the rails, and probably c2x1x/18 or c2x1x3/16 for the crossmembers if you use a subframe over the truck frame. if you don't have a subframe you might want a couple of c3x4.1 crossmembers for strength and rigidity.
i've seen some hydraulic dumps for standard beds, and they just had a 1/4" plate that went under the bed to spread out the load, so you should be able to easily make a mount off the subframe or crossmembers that will be plenty strong. there should be some standard kits you could buy to adapt to your needs, or if you have the time and dedication, you could assemble your own. search ebay and the likes for "12v hydraulic" and you will see what you need to power a bed lift. you will also need a remote switch and a cylinder, so i would suggest searching for complete kits and then look at what is needed and see if there is a way to scavenge pieces cheaper.
one last thing to consider - check with your insurance company. a couple years ago i bought a ton dump that is for maintenance on my own property (not for hire). i found out that i couldn't group it with the rest of my vehicles - it needed a commercial policy because of the body. if it had been a standard ton dually with a regular body i could have insured it with the rest of my personal vehicles. i asked a few questions to make sure i understood the requirements, and it was because of the body and not the size/weight of the truck. any truck with a non-standard body was required to have a commercial policy. i checked with another insurance company, and they mirrored the claims of the first company. for what it's worth, the commercial policy was not really much more money than the regular one.
i know there are tons of older trucks with homemade bodies due to sheet metal rot, and i would bet that very few people have commercial policies. if you go to your insurance company and just tell them the year and make, i'm sure 99% of the agents wouldn't even ask about any modifications, so most people are probably flying blind. it may vary by company or by state, but i got the same story from two separate agents. i can't say whether an insurance company would deny a claim based on this, but the only way you would find out is after an accident happened.
/ Flatbed
Thanks guys for the input and ideas. I think some of you are right, in that the truck is just too small to use for a dumper. I keep it because I bought it new in 95 and paid cash for it, and it's been ultra-reliable ever since...it's like a "friend" now! I could find a beat-up used larger truck for a good price and make a dumper out of it, with an available kit. I just can't have 2 trucks here so I'm kind of stuck. The Ranger is worth a little more to me than the book value simply because I can rely on it, but maybe it's time for it to find a new home....
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63291)
KNOW BEFORE YOU...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A59911)
2001 FREIGHTLINER...
LANDPRIDE FDR1648 - 48" FINISH MOWER (A64280)
LANDPRIDE FDR1648...
2012 FORD F-250 SUPER DUTY SERVICE TRUCK (A64280)
2012 FORD F-250...
211299 (A62131)
211299 (A62131)
9 SHANK CHISEL PLOW (A63291)
9 SHANK CHISEL...
