Ballast Wheel weights DK40SE
/ Wheel weights DK40SE #1
tabacman
Member
NW Indiana
Kioti DK40SE HST
Anyone out there used or recommend bolt on wheel weights for a DK40SE HST?
I will fill the tires if I have to but I prefer something I can lift in sections or plates. I don't have any way to wrestle with 900 lb tires either - need a lift or another tractor! My brother-in-law, myself and a couple of 12K bottle jacks are all I got.
Just curious if anyone has been down this street already and has a report.
Thanks.
/ Wheel weights DK40SE #2
KIOTI offers a bolt-on rear weight kit for your tractor. The carriers will handle 2-75lb weights per side. We have sold quite a few recently, since it offers the flexibility to remove the weight when you don't need it. Not as much weight as Rim-Guard, but along with a 3-point attachment, can offer good ballast for loader work.
/ Wheel weights DK40SE #3
Will the wheel weight kit work with my DK45S with R-4 wheels?
/ Wheel weights DK40SE #4
@ Hoosier man. A NEW/recent Tractor With R-4's from KIOTI, cannot accept wheel weights. The only way to add ballast is a box or fill tires with fluid.
Sorry! However if you ever need front weight, A suit case weight bracket and weights are available.
Tony
/ Wheel weights DK40SE #5
Can you add weights to R1's? What size of R1's does a DK45 accept?
/ Wheel weights DK40SE #6
@ Hoosier. A DK45S r-4's should be able to accept factory wheel weights. How to check - Do your tractor wheels have three 5/8" or 3/4" holes in them? They should be in a triangular pattern. If you do they have the correct pattern and your local KIOTI dealer can order them for you. I have seen people use as many as 3 or 4 on each side. Caution though - your using Grade 2 ALL THREAD! I would recommend finding some Grade 5 or 8.
Sorry for the previous post - I was brain dead. You said DK45S - I was think 55S.
Tony
/ Wheel weights DK40SE #7
Thanks! Yes my wheels have three holes in a triangular pattern.:thumbsup:
/ Wheel weights DK40SE #8
Tony
Or maybe even a few more. I don't know about the all thread though, my weights bolt to each other with grade 8 bolts. :thumbsup:
/ Wheel weights DK40SE #9
We have KIOTI Rear Wheel Weights for the DKSE Series R-4 Wheels. As we said in our earlier post, the KIOTI Kit accepts 2-75lb weights/side.
They also fit the R-1 Rims.
2007 30ft. Regal 30 Express Cruiser Boat with 2010 Vantage T/A 33 Ft. Trailer (A64557)
2007 30ft. Regal...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
90in. Work Bench (A65640)
90in. Work Bench...
Heaven Hill Burbon Barrel (A65583)
Heaven Hill Burbon...
Club Car Emergency Cart (A64557)
Club Car Emergency...
2019 Mercedes-Benz Sprinter Box 1500/2500 Van, VIN # WD4PE7ED3KT012316 (A65563)
2019 Mercedes-Benz...
