mounting lights to rops
/ mounting lights to rops #1
twinsticks
NJ
2005 BX 23
Anyone have any pics on how to attatch 4 lights to the rops on a bx 23 without drilling looking for a bolt on.. Been searching all the threads cant see to find any...
/ mounting lights to rops #2
I've been trying to decide between milling my own brackets out of aluminum, or just using 4 x 2" square u-bolts to mount lights to my BX2660. Money is short, so I won't have to make a decision for a while. :) Post pictures of what you go with!
/ mounting lights to rops #3
Thanks for the pics that is the route I am going bought everything tonight at tsc ..... 1 by 1 aluminum square tube with 4 inch ubolts.. Your light bar looks great I see you even painted it to match your tractor.
/ mounting lights to rops #7
I'd go with steel on the 1 in tube. Tightening the lights on mine was enough to bend the steel one.
Just my 2 cents.
Could not find steel anywere around me without traveling at least a 1 and a half from my home.. We will see how the aluminum holds up
/ mounting lights to rops #9
How did you do the electrical? Fusing, connections, wire routing, wire size, etc.
/ mounting lights to rops #10
/ mounting lights to rops #11
Ran battery and ground wires (14ga) the full length of the tractor to the battery. Used the fuses that came with the lights. Relay latches +12v from the battery to the lights with the +12v trigger from the right headlight.
Also used a 4pin trailer connector at the base of the ROPS incase the "light bar" ever needed to be removed.
Since the install of the lights, I now use this wiring for the 25 gal sprayer I have too...Connect the additional 4pin connector: Turn the headlights on = spray, Turn the headlights off = stops spraying.
/ mounting lights to rops #12
Thank you. I hope to do something similar with my L3240.
How did you make the connection into the battery--physically?
2015 Gravely ZT 42in. Zero Turn Commercial Mower (A64194)
2015 Gravely ZT...
2015 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2015 Peterbilt 320...
2022 EZ-GO ELITE...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
Frac Manifold T/A Trailer (A64194)
Frac Manifold T/A...
