2360 ready to go
/ 2360 ready to go #1
blackd
So MD
Yanmar FX24D replaced with Massey GC2400
Finally got around to finishing the 2360 set up. It took about 6 hours. We had a 1 3/4 inch snow Thursday, so thought it best to get it ready.
A note for those of you who have gravel/stone drives, the feet may be too short. I went through two shear bolts in first pass of drive from stones jamming fan. My deet are as low as they can go, and I have a washer between the foot and frame on the top bolt. That tilts the foot back to get an extra 1/8 inch lift. I might shop around for taller/longer versions.
Anyone have any ideas?
/ 2360 ready to go #3
wait until the ground freezes?
/ 2360 ready to go
It is frozen now, but not too deeply. We live in So MD, and ground may never freeze or stay frozen. It's pretty common for us to have storms that start or end with rain/sleet. It's also common for us to get dumped upon once or twice a year, or have have a year when there's no more than the 1 3/4" per storm we just received.
/ 2360 ready to go #5
See my post a few years ago, has worked well since, blower housing has been scarred up due to county grader leaving gravel/stones mixed in with the snow (not my gravel!) at end of drives.
This will leave some snow over the gravel and cover the gravel so it doesn't pick up, don't try to remove every flake of snow, then you will run into gravel again!
http://www.tractorbynet.com/forums/...ing/133326-2650-blower-mod-gravel-drives.html
/ 2360 ready to go
Thanks, Amfken.
/ 2360 ready to go #7
that sounds similar to where i'm at now... i'll just be using a blade from now on.
/ 2360 ready to go #8
IIRC where the sub-frame connect to the blower you can change the blower angle of attack several degrees. Angle the blower back slightly may help but overall I have the same problem, the stock shoes are small (sink into softer stuff easily) and don't offer quite enough height adjustment for gravel roads. The main issue is the uneven nature of gravel roads are often high centered and when the blower shoe straddle the the high points your blower becomes a grader. To help with this I fabricated a center shoe for the blower which definitely works great for helping to float the blower but at the expense of a much messier looking job. I'm just starting my second season and have paid special attention to the grading the road to eliminate, as much as possible, any high spots and areas of loose non-compacted stone.
Here's the link to a thread with pictures of the third central shoe.
http://www.tractorbynet.com/forums/build-yourself/160347-massey-ferguson-mf2360-blower-third.html?highlight=shoe
/ 2360 ready to go
Well, this is embarrassing! After looking at the pics, I have my skids on backwards. Will, get back after changing them in the next few days.
/ 2360 ready to go #10
Yes, that would help too. :D
/ 2360 ready to go #11
Packing down and not removing the first few inches (at least) of snowfall saves so much trouble on a gravel surface.
/ 2360 ready to go #12
Wish I lived where the weather was consistently cold for the practice to be effective. Last 10 years or so it seems many snowfalls are interceded with warmth or rain therefore creating a huge slush mesh if anything is left on the road.
New/Unused Wolverine Quick Attach Quick Coupler (A65583)
New/Unused...
Bombarder Sea Doo GTI (A64127)
Bombarder Sea Doo...
2022 EZ-GO ELITE...
2019 PITTS CONTENDER LD35-22DC RGN LOWBOY TRL (A64277)
2019 PITTS...
John Deere 1770NT Planter Drive (A65640)
John Deere 1770NT...
2007 CHEVY C4500 WESTERN HAULER (A65643)
2007 CHEVY C4500...
