hyd fittings
/ hyd fittings #1
Kitz
anywhere usa
IH 244
Hi everyone im not sure if im in the right forum but it sounds good i have a bush hog 1840 loader it has 1/4 " hydraulic lines i dont know what the name of the fittings are to order new ones :confused: they have a flare on the male ends about the size of a 1/4" pipe nipple any help would be appreciated
/ hyd fittings #2
A picture would help the most. It is probably a JIC fitting.
/ hyd fittings #3
We could nail it down for you in 2 seconds if you can post a picture;)
/ hyd fittings #6
Can't really say without a picture. But it's probably either a JIC fitting or an NPT fitting.
If you can get us a picture that would be great. :thumbsup:
Chad
/ hyd fittings
here are a couple pics they are not real clear but i think you should be able to tell i miked the male end and it was .557 not sure if that would be #4 or#6 if it is jic ive seen some that are 37 degree? also is it ok to put t-fittings bullheaded instead of on the run thanks
/ hyd fittings
on my loader the hose goes to a tee one outlet to cylinder other outlet to other side cylinder on this loader all lines are 1/4" hose w/female ends id like to turn tee to avoid hose kinks
/ hyd fittings #11
OK, I think I understand, (that was hard to read though). You can put the Tee's anywhere, it will not matter.
2012 International (A59230)
2012 International...
2008 Kubota RTV 900 4x4 Fire Rescue Diesel Utility Cart (A61572)
2008 Kubota RTV...
4004SFL (A59228)
4004SFL (A59228)
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
2020 MACK ANTHEM 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 MACK ANTHEM...
207271 (A52708)
207271 (A52708)
