F-220
/ F-220 #42
According to this video:
YouTube - Kubota Battery Basics
the 850 cold cranking amps is minimum. So if i have only 680 EN ( I have found out that EN stand for "European standard" and it is the same as CCA) Should I look for something bigger? There is some free space around the battery so I think I should be able to fit something bigger.
I have cleaned all battery connections. So that is not what causes that problem. I'd buy this Block heater If it was available. It seems you can't get one here in Poland :(
I haven't tried to lift it. Maybe tomorrow I'll try to lift it above that lock.
You need to clean and tighten also connection on the starter relay and ground connection from battery at the chassis.
/ F-220 #44
Nothing unusual happens ;) The 3 point hitch goes all the way up. I haven't noticed any unusual sounds or anything else. Maybe it has something to do with PTO shaft? When the tiler is raised all the way up the PTO may disconnect in the middle? Maybe this lock is there to prevent it?
/ F-220 #45
That is possible. If I raise my tiller to full height the drive shaft begins to bind a little bit. Same with a cement mixer I have. Just need to be observant with all pto driven implements making sure everything is OK.:thumbsup:
2012 CHEVROLET IMPALA CAR (A66091)
2012 CHEVROLET...
2015 Ford F-250 4x4 Crew Cab Pickup Truck (A66736)
2015 Ford F-250...
CAT 966D Grapple / Bucket (A68134)
CAT 966D Grapple /...
2012 CHEVROLET SILVERADO 3500HD CC (A67714)
2012 CHEVROLET...
2007 REINKE TRAILER Combo Spread Axle Flatbed (A67714)
2007 REINKE...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
