Front Dethatcher?
/ Front Dethatcher? #1
Brack
Member
Green Bay, WI
JD 2210
I see JD has a front-mounted dethatcher available for their X-series, but nothing for the 2210. Does anyone have an after market model that they use and like? I use the JD MCS and would like to cut down on the number of passes I make this coming spring on yard clean up. Any assistance would be appreciated.
/ Front Dethatcher? #2
Sorry--can't help with a front dethatcher, but after owning mine for a couple seasons I wouldn't want any other. The obvious downside is you can't vacuum at the same time, but my brother and I team up--I run the dethatcher on my tractor and he follows behind with his tractor and the vacuum. This particular one is 5 feet, but the guy who builds them has 6 to 10 foot models as well.
/ Front Dethatcher? #3
What brand is that made by???
/ Front Dethatcher? #4
You are correct, JD does not make one for the 2210/2305.
When I had my X500, I had the front dethatcher. I then bought
a 2305. Dethatcher would not fit.
I therefore, made my own bracket to work on the 2305. 2 bolts and
it's mounted to my 2305. What takes longer, is putting the bracket
on the tractor that supports the lift handle of the dethather.
I also had to make the lift handle longer to work with the 2305.
But, even with that, probably 5 minutes total to put everything on.
JD Greg
/ Front Dethatcher? #5
It's made by a very small company (1 guy working out of a pole barn) called CMP Attachments. I stumbled across his ad on Cragslist and he actually supplies a few of local JD dealers with them (they paint them green and add some margin).
The weight of the unit itself combined with the weight of the 3 point system (you leave the control lever for the 3 point in the down position so the dethatcher "floats" and can move up or down) provides the necessary downforce.
It really does an amazing job and with 5 feet per pass it takes very little time to dethatch.
Bob
/ Front Dethatcher? #6
I bought JD's front dethatcher for my X595 this fall, but too late to get much use of it. It was pricey -- with 8" extensions to make it 54" -- $450. The dealer gave me $100 trade-in for an old Stihl chainsaw.
Before buying it, I found at least 2 companies online by googling "dethatchers", and who make equivalent units. Their prices were on par with JD, so why bother -- I know I can get decent support from the local dealer. Anyway, there's companies out there, just do some websearching.
JimP
/ Front Dethatcher? #7
Hi I see you guys are looking for dethatchers I own CMP Atachments and I make them for 3 point or also for the front of a compact tractor. You can call me if you are in need of on 763-443-7861 Derek::)
/ Front Dethatcher? #8
JimP
I've been using the JD front-mounted dethatcher on my X300R for 2 years now. Works super in combo with my mower deck and rear bagger!! Makes Spring cleanup a sweet sweep... (say that real fast 4-5 times!) :D
Regardless of the manufacturer - a front mounted dethatcher with a mounted bagger is the hot ticket - IMO.
(There's always a but.... watch out for dried grass buildup on top of your deck - it's not a good situation with fast moving belts and pulley's!!)
AKfish
2013 Caterpillar 420F Loader Backhoe (A68183)
2013 Caterpillar...
2013 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2013 FORD F150...
MANIFOLD (A68842)
MANIFOLD (A68842)
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2018 WILDCAT (A67714)
