Ford 445 Steering
/ Ford 445 Steering #1
BuzzyG
My backhoe steering wheel spins with very little resistance and no effect on the wheels. After much spinning, the wheels will turn and the steering wheel stops when the wheels reach their fully turned position.
Any suggestions will be gratefully received.
/ Ford 445 Steering #2
Fill the power steering reservior which is attached to the power steering pump at the left front of the engine. New Holland 134D hydraulic oil or its equivalent. Fill until it runs out the neck. If that doesn't cure it , post back.
/ Ford 445 Steering
Thanks! I will do that first thing in the morning. (I am on central time.)
/ Ford 445 Steering
Hey, RickB,
Fillin er up did the trick. Thanks a million for such a simple fix.
Always before, low fluid resulted in really hard steering. What is the deal? Do you know?
/ Ford 445 Steering #5
Hey, RickB,
Low fluid level in a power-assisted system (has a mechanical connection between steering axle and steering wheel) results in hgh steering effort.
Very low fluid level in a hydrostatic steering system (no mechanical connection) means little or no resistance at the steering wheel and little or no steering response.
/ Ford 445 Steering
I am blessed that you are willing to share so freely.
Thanks again!
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
2016 Ford F-150 4wd 4 Door (A63689)
2016 Ford F-150...
4022CFL (A59228)
4022CFL (A59228)
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
NO ADDITIONAL ONLINE BUYERS PREMIUM ON BID.FIVESTARAUCTION.COM (A64047)
NO ADDITIONAL...
Pallet Fork Extensions (A64047)
Pallet Fork...
