Slowing snow plow movement
/ Slowing snow plow movement #2
I put one in my plow setup to control the up/down lift speed and found after I got used to the controls, cracked it wide open and rendered it useless. Wasted $39. It's still in the circuit just not of any function.
:laughing:
I tried feathering the remote lever, but I think the flow is just too much for those small angle cylinders. I just barely cracked it and it swung in a hurry. I am not crazy about about spending $80+, but don't want to damage anything.
/ Slowing snow plow movement #4
Have you tried idling down the tractor first? I have no problem with my Meyer plow on the remotes of my Jinma but its only 5 gpm flow rate.
Chris
Chris
I haven't, but it is a hydro and I'm not use to adjusting the throttle once I get rolling. It is a Meyer plow and I put new cylinders on it. I want to make sure I don't damage the FEL.
/ Slowing snow plow movement #6
The adjustable ones are cheaper at the Surplus Center: https://www.surpluscenter.com/item.asp?item=9-5300-25&catname=hydraulic
Or you can get "fixed" ones for much less, it's just a swivel fitting with a very small hole in them: Swivel Adapter, 3/8 in. Restricted Male Pipe x 3/8 in. Female Pipe Swivel - 1818147 | Tractor Supply Company
I was looking at the 1/2" model. The price is about the same. Since I'm unsure how much I'll need to restrict the flow, I think I'll go with the adjustable model.
So far, I haven't seen any concerns about adding these to the circuit. Again, I'm assuming I'll add them just before the cylinders.
/ Slowing snow plow movement #8
Your cylinders probably have 1/4" NPT fittings...you shouldn't need 1/2" ones. No troubles at at using them.
/ Slowing snow plow movement #9
Take a suitable male/female fitting and braze the passageway shut.
Drill a small (maybe 3/32" or 1/8") hole to restrict flow.
Start small and enlargen 'til you get the flow U want.
Amazing what you guys are able to do. Thanks for the link. I'll ponder making my own.
It works! Made the restrictor without the wire (didn't have anything that small). It still moves pretty quickly, but I don't feel out of control and I think I'll be fine.
First snow of the season headed this way. Great timing!
Total cost under $5.
Thanks again,
/ Slowing snow plow movement #13
Thanks again,
Awesome:thumbsup:
/ Slowing snow plow movement #14
Thanks again,
Glad you made it! Gr8!
The loose wire have two purposes....tuning the size of the hole and keeping the hole clean from clogging....
The wire would be an easy addition, if I had a wire that small. Don't have a hardware store in town, only box stores. Do you have a recommendation for possible sources?
Thanks,
/ Slowing snow plow movement #16
I use brake hose sized lines and mine is just perfect for angle speed. My loader valves are graduated, also. That's what I use for the plow cylinders
/ Slowing snow plow movement #17
The wire could be copper from a piece of electrical wire or a paper clip. Paper clips come in different sizes and wire size.
/ Slowing snow plow movement #18
/ Slowing snow plow movement #19
Thanks,
How about the music instrument store...guitar strings
Even rigid copper wire could work....from stranded electric wire...
American Wire Gauge, AWG
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2016 VOLVO EC250EL EXCAVATOR (A62129)
2016 VOLVO EC250EL...
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
2006 FREIGHTLINER M2 106 T/A BOX TRUCK W/100 PSIG AIR PUMP (A59912)
2006 FREIGHTLINER...
