Hydraulic Flow Control Advice Needed
/ Hydraulic Flow Control Advice Needed #1
Monster5601
Platinum Member
Oakland, MI
Kubota B3030 R4 Tires
I need to know how to go about adding, or actually restricting, the hydraulic flow going to my Curtis hydraulic angle snow blade. The snow blade, mounted to my Kubota RTV, uses the same hydraulic circuit for the dump bed but I only want to slow the speed of the angle adjustments on the snow blade. The hydraulic control does not lend itself well to feathering.
Pictured is the snow blade attached to the front of the RTV. The hydraulic circuit connects to the front of the RTV and then into a pilot-check valve (all Kubota factory). I'm assuming the proper place to position flow control is in the circuit between the RTV and the check valve.
Do I need to add a flow restrictor on one hydraulic line or both?
Were is the proper location for the flow restrictor(s)?
Any recomendation on type of flow control, say washer versus adjustable valve?
/ Hydraulic Flow Control Advice Needed #3
Several yrs ago I put an adjustable flow control valve on a Kubota M4900 FEL to control boom lowering speed when handling 4X5.5 rd bales. With adjustable FC valve cylinder speed can be fine tuned. I agree valve can be installed on either pressure or return line
/ Hydraulic Flow Control Advice Needed #4
You can restrict either flow or return, but IME, restricting return works best. You create back pressure in the cylinder and prevent over running due to lack of oil available when restricting the pressure side.
You can braze a fitting shut and drill it to create an orifice. This allows you to play with the size to get the speed you want. Start with a 1/32” orifice and go from there.
Or add the adjustable flow restrictors.
/ Hydraulic Flow Control Advice Needed #5
If you only put one in, make sure the control is bidirectional. Some of those control valves (shown above) have control in one direction and free flow in the other. Sometimes you want this, sometimes you don't. In your case, I think you'd want bidirectional.
Edit: Well, Rich beat me to it. (y)
/ Hydraulic Flow Control Advice Needed #6
This is what I did on my backhoe's boom cylinder which was way too jerky, probably due to inexpensive valves. I put a one way adjustable valve on both ends, restricting the flow out. I wanted separate adjustments for each end because the rod end needs less fluid to move the same distance, and also gravity acts on the boom.
Thank you for the advice but it leads to another question.
Since the angle blade is bidirectional, how can I determine which line is pressure and which one is return since they have to exchange roles depending on the blade direction?
/ Hydraulic Flow Control Advice Needed #8
Do you have a schematic? My best guess is you need the adjustable type adjuster that allows free flow in one direction, restricted flow in the other on the lines to your plow from your vehicle.
/ Hydraulic Flow Control Advice Needed #9
Both lines are alternating pressure lines depending on which way you move the valve. The line that's "not pressurized" gets dumped to the tank. That's why if you use a single flow restrictor, you want a bidirectional restriction. (It will slow flow in either direction.) The rod side of the cylinder will still move a little faster since the cylinder volume is less.
/ Hydraulic Flow Control Advice Needed #10
Bidirectional flow control valve: 1/4 NPT 5 GPM Needle Valve Wolverine by Prince Mfg WNV-400 | Wolverine by Prince Mfg | Brands | www.surpluscenter.com
Single direction: 1/4 NPT 5 GPM Prince WFC-400 In-Line Flow Control | Prince Mfg | Brands | www.surpluscenter.com
I'd put the bidirectional control on the piston end of the cylinder as that end flows more. When compressing the cylinder it will be pushing oil out past the control. When extending, oil will be pushing through the flow control into the cylinder. You can plumb it in between the relief valve and the hose to the appropriate end of the cylinder where its easy to get to.
I think that since there is no gravity involved (it's pushing side to side not pushing or pulling up) a single control would work fine.
I'd use a low gpm valve like these 5 gpm ones to get the best adjustment range.
/ Hydraulic Flow Control Advice Needed #11
Here is good link for restrictor fittings.
/ Hydraulic Flow Control Advice Needed #12
Looks like the blade uses a pair of single acting cylinders. SO in you case it doesnt matter which line it goes on. Because one line is supply and the other is return when angling right. When angling left their roles reverse. But yes, get a bi-directional control and you can tailor it to the exact speed you want.
Just make sure you put the control on one of the lines going from the machine to that crossover valve. If you put the restrictor on one of the lines going from the crossover valve to a cylinder, it defeats the purpose of that valve.
/ Hydraulic Flow Control Advice Needed #13
On a pair of single acting cylinders I would just get a simple needle valve aka throttle valve and just skip the kind that has free reverse flow, because all that does is give you an opportunity to put it in backwards. Normally using a simple 'restrictor' like a needle valve or fixed orifice to one side of a dual acting hydraulic cylinder will give you different speeds in each direction because of the displacement differences between the rod end and the base end, but on a pair of matching single acting cylinders both 'sides' have the same displacement and flow rate so the 'free return flow' feature is useless complication. My .02.
To put a closure on this, I found and ordered a bi-direction flow control valve from Summit Hydraulics with 1/4" FNPT openings. I sure want to thanks all the folks that gave me a heads up on bi-directional versus uni-direction flow control assemblies. It save me from making a mistake as I didn't know there were uni-flow values.
I got the new flow control installed today and it works like a dream, I now have a reasonable speed on my blade angle adjustmens.
Thank you thank you thank you for all the advise and information, you saved me from making mistakes.
