stump speech
   / stump speech
The feather action on your hyd valve should let you work as slow as you want. After the stump is pulled, the pressure will go down according to the weight of the stump. If you install the gage, you will see the working pressure at all times.
The thing about the pressure, is that you may need all of the pressure the pump can provide, and after you break the stump out of the ground, the pressure will fall quite a bit.
With nothing attached to the cyl, very little pressure will extend the ram, or pull it in.
After the stump is pulled, you can switch to single chain and do whatever.
I got ya. The rear remote levers have a short throw and detents, but I guess there is a bit of feather in there. I'll swap them around and use the one that works the grapple, that seems looser maybe just because it's been used. I'll keep an eye on the gauge.
   / stump speech #92
Ok, I guess I missed the fact the Farmi JL 601 is a log winch. I'm a little puzzle by Dead Horse statement, since I seen my neighbor use his to pull stumps out. His lets his dig deep into the ground which will stop the tractor from moving. :confused:
Like I said, the 601, which is a BIG winch, has a capacity of 13,200 pounds........ any stump that you can pull out with that level of force or less is easy pickings for the winch. Jake's setup is applying 28,000 pounds.
It does not matter if you wedge the big winch into a stump or use the dozer blade to do it....... 13,200 pounds of pulling force is all you are going to get.
Back to business............. Jake. go get some of these at the nearest logging supply place, in grade 120......... you will not break them. I have one in square edged links on the back of my winch.......... unbreakable for the kind of loads you are playing with.
   / stump speech #93
What if you had a couple snatch blocks Dead Horse, ran your winch line thru a snatch block on a anchor point(big azz tree) to the stump with a choker cable/chain connected to the other snatch block with the bitter end attached back to the big azz tree. You would triple your pulling power and most of the pull would be on the big azz tree and not the tractor plus your out of harms way if something breaks.
Rick
   / stump speech #94
Understood, and agreed... However, Jake does not have my winch nor my tractor............. we are talking about HIS stumps and how HE pulls them........
I just knock trees OVER, stumps and all, with my big tractor, cut the stumps off of them and move them to the stump dump. BUT WE AIN'T TALKING ABOUT MY STUMPS!
This thread is about admiring what Jake put together and how he made it work and some of us are just trying to see if we can armchair quarterback his effort and not look like total fools ourselves...........
   / stump speech #95
I was running it by you more for myself Dead Horse sorry if it came as telling you what to do.
I will be spending a couple months in Oregon this winter and have a bunch of stumps that need to go. That is y I was keeping a eye on Jake's progress as his looks like an inexpensive way to do it.
We only have a tiny tractor at the farm and any $ spent to do a project will come out of my pocket so was looking for a way to make use of what we had with minimal investment unless I can talk the uncle's into splitting the cost of a bigger tractor/winch for logging ourselves next time as well as getting these stumps and other projects done. Otherwise my choices were dig them up by hand with another cousin or I pay for the rental of a excavator. Family politics can be almost as much fun as the real thing.
Rick
   / stump speech #96
Since your statement puzzled me so, I check with my neighbor who is tree farmer and landscaper. He also has a 601. He told me when using a log winch you need to set the 3-point hitch to float to allow the the winch bottom to dig in. He stated the only time he has had any issues with dragging the tractor is when the ground is frozen. During the winter he will brace it against a stump or some other ground irregularity to get it to dig it. Digging the winch bottom into the ground creates such a good anchor he has be careful not to break the cable when pulling really large log bundles or stumps. Unfortunate he has done this at least 4 times, which why he uses an extra long control rope now.
He also made a point to be very careful winching up hill. He said he almost flip his tractor over once, which I believe is 90 hp JD, when winching a bundle of logs up a hill. There was so much force on the winch it lifted all 4 wheels of the tractor off the ground. Lucky one of his helper hollered at him and he release the winch just as the rear wheels lifted!
Jake98, I still think some kind of 3-point hitch winch frame will simplify your stump removal task.
   / stump speech #97
Rick
Gottcha!!!!!!!! If it were me, I would go with renting an excavator for the day. a good size one can get a lot of work done in a day!
Plus the way Jake is pulling stumps is cheap, but it ain't easy by any stretch of imagination. Lotta humping heavy stuff around, rigging and re rigging........ But looka the size of him!!!!!!!!! he kin prolly pull a stump by hand iffn he gets a mite agitated!
   / stump speech #98
I understand all about digging the dozer blade in........:thumbsup: I also understand that by running the cable down to the stump, through a block and back to the winch, I can double the pulling power.......... got it.
I use block and tackle for several things around my farm and understand the principle... Sorry I was not clear on the matter.....I was focused on the stuff Jake is doing here and also did not think that small winch pictured earlier in the thread would be much use for pulling stumps, at all.......
My tractor's weight exceeds the clutch capacity of my JL 601, so before the tractor comes off the ground, the clutch slips....(with a single wire pull) and a guy who breaks a cable repeatedly on a 601, is not paying attention.........:eek::eek:
   / stump speech #99
Plus the way Jake is pulling stumps is cheap, but it ain't easy by any stretch of imagination. Lotta humping heavy stuff arouns rigging and re rigging........ But looka the size of him!!!!!!!!! he kin prolly pull a stump by hand iffn he gets a mite agitated!
:laughing::laughing: He is smarter than I was when I was a youngn, y do it by hand when you got hydraulics.
Unfortunatly the only excavator for rent within 100 miles is only a 6000 lb machine and I have a bit over 100 stumps smallish ones going 20 inches and the bigger ones 30+ so not sure a day would do it. Have never used one so there will be a learning curve and I don't know if it is big enough to just pluck them out or if I will have to work at each one for awhile.
Rick
   / stump speech #100
Rick
A 6000# machine is not a big one at all, but they CAN dig quite well (if you know what you are doing with them). A 30 inch stump is a big mutha, but digging around it can go a long way to losening it. The deeper you dig, the less the stump has to hold on to.
Them little tracked excavators can be pretty strong pullers too, if you set the pull up right. Get some real strong chain, like 20 feet of it, with heavy hooks on both ends. Once you have dug around the stump some, go at it with the bucket and boom to see if you get it somewhat lose. Then wrap the chain around it securely with the other end attached to the frame of the machine, DOWN LOW. Take the slack out and use the bucket and boom to brace the machine, (place bucket on ground on back side of stump). Then move the machine away from the stump, SLOWLY........ done right you will pull the big ones out in no time.
The smaller ones you should be able to dig out. BUT A HUNNERT OF 'EM???????? Best bring yer lunch! you need a D9 with a scarafier blade! or dynamite........ we usta use that for the job..... neighbors get figity about it though..
Jake When ya gonna pull a big one out???
2008 BMW 535xi AWD Sedan (A50324)
2008 BMW 535xi AWD...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
BOMAG BW5AS DOUBLE DRUM COMPACTOR (A51242)
BOMAG BW5AS DOUBLE...
2008 GMC C7500 Altec LRV55 55ft Forestry Bucket Truck (A50323)
2008 GMC C7500...
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
HOPKINS 40 TRI-AXLE DATA VAN TRAILER (A50854)
HOPKINS 40...
