which semi mount
/ which semi mount #1
samoht
Massey 2660 HD
Have been spending way too much time dragging a 1 bottom plow around and finally bought a new tractor (massey 2660 HD). Which would better fit its capability 3 or 4 bottom 16" Ford 151 semi mount plow? Soil here is slightly hilly, mostly sandy with a few small heavy low spots. Thanks for the advice.
/ which semi mount #2
I'd be with a four bottom for that size tractor.
/ which semi mount #3
If the soil is sandy and easy to pull 4 btm would be good if the tractor is
4wd, if 2wd 3 or 4, depends on how fast you want to pull the plows. We have a set of ford 151 (same as oliver and white plows) they are a very easy pulling plow.
/ which semi mount
I will go with 4 then. It is 4wd with loaded rear tires. Ive heard that these plows, along with White and Oliver pulled real nice. Heard the Kverneland plow pull nice too but they are price like they are trimmed in gold.
/ which semi mount #5
3 bottom, 4 might be too much in the hills with 70 pto hp.
Air Vents (A60353)
Air Vents (A60353)
2025 LandHonor BS122500G Skid Steer Bale Spear Frame (A60353)
2025 LandHonor...
2025 SDLGC100 6 Passenger Electric Cart (A60352)
2025 SDLGC100 6...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
2025 LandHonor LHR-WG1507 Walk-In Greenhouse (A60353)
2025 LandHonor...
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
