stump speech
   / stump speech #41
Looks big enough to me.
A good size cable and snatch block would double your numbers.
   / stump speech
Yea, but it all becomes a question of what I can carry.. what does a 60,000 lb. pulley look like? How big of a cable?
edit: gotta love google. apparantly they use 7/8 cable for 60,000 lb. roll-off dumpsters.
   / stump speech #43
Dragging around a 7/8 cable is a pain you might wanna use spectra line, it is stronger than same diameter steel and wont rust, just dont get it hot and us have to splice it as most knot wont work.
Rick
   / stump speech
I think if it gets to that point I'll just break down and start up the old John Deere.. Maybe I'll get one of those snaggle-tooths for it, like Island's got.
   / stump speech #45
I believe I read "21 TONS" on the double pulley at this tower site.
attachment.php
   / stump speech
the tension is soon to be mounting.. excuse the pun.
   / stump speech #47
Just ordered some grade 70 1/2" chain to use doubled. That hurt. At least it's made in the USA. It gets me to 22K# working load limit. I wonder how much safety factor they figure in..
Get yourself some grade 100 square cut chain. BEST thing I ever did. The edges of it will tighten on a log (or stump) and bite right in. This of course, is when using a choker.
Grade 100 Square-Link Choker Chain - Grade 100 Chain - Labonville Inc.
(I'm not affiliated with them at all, just a very happy camper)
   / stump speech
numero uno. 8-10" (where do you measure?) this was cut last year.
   / stump speech #49
Nicely done!
   / stump speech #50
Wow, now we're talkin'! Comments? How did it "feel"? Was it maxed out? Was that size stump nuthin' for it?
Edit: I can tell you right now that, unless that had been rotting for several years or more, that's way bigger than my 40HP Kubota could push, pull, FEL curl, or 3PH lift out of the ground.
ASSET DESCRIPTIONS & CONDITION (A51222)
ASSET DESCRIPTIONS...
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
2024 CATERPILLAR 299D3 SKID STEER (A51242)
2024 CATERPILLAR...
2007 STERLING TRUCK ASPHALT DISTRIBUTOR (A50854)
2007 STERLING...
2013 VOLVO VNL860 TANDEM AXLE SLEEPER (A51219)
2013 VOLVO VNL860...
2009 FREIGHTLINER CASCADIA SLEEPER (A51222)
2009 FREIGHTLINER...
