buckeyefarmer
Epic Contributor
Anyone know where to find some 2" concrete bits? I've searched online and can't find any, except for core drilling machines. I have hammer drill.
Hilti Online - TE-Y-GB 55/59 drill bit: Item No.: 00028903
Not sure it will fit your drill.
When you say that you have a "hammer drll." Are you talking about those old fashioned drills that make a bunch of noise, but not really very good at drilling in concrete?
Or is it an SDS plus or SDS max drill?
My SDS plus is great for small holes half an inch or smaller. I use the hammer feature for taking out tile and removing morter too. Mine is a Makita, and it's a very good, lightweight tool.
My SDS max is a bigger Hitachi that can handle just about any sized bit. Ebay has Irwin bits, which are not what I consider quality, but for the money, probably decent deals.
Irwin Tools 325017 Drill Bit, 2 x 22, SDS-max One Piece - eBay (item 170571033973 end time Dec-25-10 10:30:57 PST)
I use my SDS max as a jackhammer more then a drill. Really a nice size for small projects.
If you have never uses SDS type hammers, they are just amazing. You don't have to use any force or pressure. Just pull the trigger and they just melt through the concrete!!!!!
Eddie
If only doing a few holes can you rent a core drill cheaper than buying a bit?
Just a thought...
Roy
I agree but I will say that I have some Irwin speed bore auger bits rated to cut nails if necessary. Mostly, I use them to bore PT fence posts for gate hardware but on occasion, have used them on barns and have cut nails. They have done quite well.I put a link up for that Irwn bit and after reading Harvey's reply, I wanted to clarify that I'm not a fan of Irwin products. I think they are bottom end and agree that if you get ten uses out of them, you are doing good. I haven't spent the money on Hilti, but found that Bosch makes good bits. There are a ton of DeWalt bits out there for the SDS type tools, but they don't last very long either.
Eddie
Thanks for the links. I used to have access to hilti rotary and hammer drills, yes they are nice and I know how they go thru concrete like butter. I don't have access to them anymore, that was a long time ago. I have a dewalt hammer drill I use with small bits, it drills with no problems. My neighbor the plumber has a large one he has said I can borrow, I just didn't want to wear down his bit. I have 10 holes to do, might hit rebar. I also can rent at HD.
