Trailer Ramps
   / Trailer Ramps #1
ditzel
N.J.
Mahindra 2615 Gear
I'm welding ramps for the deck over trailer I just bought 2 weeks ago. Picked up 3 20' pieces of 3" c-channel, a 4'x8' sheet of raised expanded metal, and a 10' 2" round bar. The trailer already had 3 metal eyes for the round bar to mount in.
   / Trailer Ramps
This is as far as I got tonight welding both the ramps, hope to finish them tomorrow.
   / Trailer Ramps #3
You should think about welding a leg onto the ramps. Looking good.
   / Trailer Ramps #4
Unsure of your plans but I would suggest that you have feet on the trailer end of those ramps to prevent the trailer from tipping while loading and unloading. Much less strain on the trailer and truck, much easier to load the tractor without problems. Parking brakes on your truck don't work well in the air.
   / Trailer Ramps #5
Agree on the legs for the ramps; am thinking on building a set this year to help. The standard ramps are bending slightly and it would help support on the load.
   / Trailer Ramps
Another full days work on the ramps, I had planned on using legs for support when loading. There was an existing cracked weld where the dove tail meets the flat deck that I rewelded today. Guessing it happened when they used portable ramps without legs.
   / Trailer Ramps
All thats left to do is a coat of black paint. Daylight savings sucks. Just not enough light lately.
   / Trailer Ramps #9
Really Great work. I also hate when it gets dark earlier. I wish it would stay daylight longer.
Chad
   / Trailer Ramps #10
Nice job. I bet there will be many of days that you'll be glad you did it.
   / Trailer Ramps
Finished them off with a coat of black rustoleum and finally got to test them out.
   / Trailer Ramps
I built the ramps almost a year ago, but today I welded additional supports on the ramp legs and trimmed original support leg length by 1 1/2" they were too long and rubbed the ground when unfolding them. Then I tested them out.
2004 Pierce Tilt Crew Cab Pumper Fire Truck (A59230)
2004 Pierce Tilt...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
1700 (A60430)
1700 (A60430)
EXCAVATOR QUICK DISCONNECT (A58214)
EXCAVATOR QUICK...
2014 International Derrick Digger Truck (A55973)
2014 International...
159115 (A60430)
159115 (A60430)
