Oil & Fuel B2910 trans leak - HELP!
/ B2910 trans leak - HELP! #1
kubota44
Kubota B2910
I have a lot of oil leaking and it appears to be transmission fluid. I cannot pin point down to where it is leaking at as there are several different areas where the oil is slowly accumulating. I've checked the tightness of bolts and the filter is in place correctly - any suggestions?
/ B2910 trans leak - HELP! #2
Could be a lot of places. B2910 has filters on both sides of trans. If leaks are coming from from front. May be a loose connection on power steering.
/ B2910 trans leak - HELP! #3
You'll need to clean off all the accumulated crud and then check to identify where the leak is. Run it a bit, turn it off, put the keys in your pocket, set the brakes, and crawl underneath with a flashlight and mirror and start looking around.
You say you're leaking "a lot of oil". How much? A quart every hour, or a quart every hundred hours?
