ford 70's industrial tractor start problem
/ ford 70's industrial tractor start problem #1
DWN1
SE So Dak
3- 47 M, Kubota 2330 and Ford 4500
real novice....please forgive and thank for your patience. 70's ford tractor running ok....tried to start in cold weather...had to jump start...pulled it in the barn...charged the battery...turned the key...thought I saw a puff of smoke near the pos terminal....got nothing....lights work..battery is charged...new starter last year....what should I do next
/ ford 70's industrial tractor start problem #2
smoke means bad connection.
remove and clean all connections between the bat and starter..
soundguy
/ ford 70's industrial tractor start problem #3
soundguy
Totally agree with that one don't overlook the back of the batt term if it has got one of those term with the saddle holding the wire in as they can get bad in there too
Jon
1997 FRAC TANK 500BBL WHEELED (A63569)
1997 FRAC TANK...
1998 Mack DM690SX Chassis Truck  (A62679)
1998 Mack DM690SX...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2019 F150 (A61306)
2019 F150 (A61306)
Informational Lot - Financing (A63118)
Informational Lot...
