Show me your 3pt carry-all
/ Show me your 3pt carry-all #1
Haywire
Central Kentucky
Tractorless :(
One of the first things I think want to make for my BX2660 when it gets here is a carry all for the 3 point. I envision something that will carry a half pallet (4x2) stacked about 3 or 4' high with firewood. I'll use it for transferring firewood from the wood shed to the house rack.
thanks,
Ian
/ Show me your 3pt carry-all #2
I'm thinking about building one, too, but I stopped at Del's the other day and looked at theirs. Lightweight one is only $139--hard to justify building one at that price. I think the HD one was around $200 IIRC.
Heck, a few pieces of angle like that TSC job couldn't cost much to slap together. Might go down and take some measurements if they have one in stock.
thanks,
Ian
/ Show me your 3pt carry-all #5
I have desing plans for this one. I call it a 3 point fork lift, but it could be modified for many tasks. Philip.
/ Show me your 3pt carry-all #6
Philip,
That looks very professional. Would you please post or E-mail the design plans for your 3-point forklift?
That's nice Philip, looks like it's built stout. I was thinking about using 1.5" sq tube, but realistically for what I have planned for it, 2x2x1/4 angle will probably suffice.
Ian
/ Show me your 3pt carry-all #8
Here are the plans. Philip.
  • PALLET.pdf
/ Show me your 3pt carry-all #9
I tend to call mine a Tote Box rather than a Carry-all. I haul wood with it and the wife uses it to work her flower beds. I've attached a couple pics and my plans. The best part of it was building it myself. Good for the Soul. :)
  • Tote Box Plans.pdf
/ Show me your 3pt carry-all #10
Ovrszd.
How much front weight to off set rear load?
/ Show me your 3pt carry-all #11
Haywire, unless you are just trying to use material that you already have on hand, I'd suggest at least 3X3 X 5/16 (or 3/8) or maybe even 4X4 X 5/16 (or 3/8). It won't cost that much more but would be able to handle more weight. I tend to over build for the "just in case" and 2X2 X 1/4 is pretty light.
/ Show me your 3pt carry-all #12
This one's based on a KK from TSC. The sides and seat are removable and it is equipped with a receiver hitch. The floor and back are 2x12's and the sides are 2x10's. The girl was an extra cost option.
/ Show me your 3pt carry-all #15
I use mine mainly to carry water out to the newer trees. The planking is just wide enough for two 55 gallon drums. I'm guessing a full load weighs about 1000 pounds including all carry-all material. A 12 volt pump works nicely for watering and that is mounted on the top rear of the carry-all.
/ Show me your 3pt carry-all #16
Did not build a dump in it, but I find lots of uses for it. This is a load of wood for the OWB.
Thanks for all the ideas. I'll go price some steel and see what I come up with.
Ian
/ Show me your 3pt carry-all #18
Here is what I made if you don't need it real big. I use it as a carry-all, and weight box. I use gravel for weight and when full it's more then enough.
/ Show me your 3pt carry-all #19
Bought the frame from TSC then attached some 2X12's & 6" PVC
/ Show me your 3pt carry-all #20
Runner
I was inspired by your construction & just went & bought the carry-all from TSC. Could you advise what the green metal brackets that your sides lock into are called ? Gonna steal your construction plan and make a seat for my Queen as well....... perhaps I can get some work out of her if I'm tricky enough.
Walnut Picnic Table (A66408)
Walnut Picnic...
2015 Ford F-650 Altec AP40 35ft. Bucket Truck (A64194)
2015 Ford F-650...
John Deere 230 Disc Harrow (A66285)
John Deere 230...
Mayrath 10" x 30' Truck Auger (A66285)
Mayrath 10" x 30'...
New/Unused SDLL580 Mini Track Loader (A65583)
New/Unused SDLL580...
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
