HF mower?
/ HF mower? #2
Gotta love the description.. 'You're done with all the big mowing; now it's time to finish up around the shrubs and along buildings.' ..they have no idea what it's for..
/ HF mower? #4
That is a steal. My local store had them in stock a few years back and a friend bought the 6' version. Only issue he has had is the wheels are cheap and he finally replaced them. He mows 4 acres each and every week for 3 seasons now with no other issues.
Chris
/ HF mower? #6
Chris
dang.. 375$ ? if my local store has one.. I may be hauling one home after lunch.. hafta go check that out.
soundguy
/ HF mower? #7
A 5' foot rear finish mower for $374.97? Not me. Not with a ten foot pole.
I am not implying this is a quality item, with that said, I don't think associating price to judge quality is a wise decision. The quality of an item should be judged with out regard to the asking price of the item.
/ HF mower? #8
I'm not very keen on purchasing anything from Horrible Freight that costs more than about $20. That's about my high end on what I'm willing to gamble with their extremely questionable merchandise.
/ HF mower? #9
For $375, I would at least have a look at one. After all, a mower doesn't have to be perfect to be functional. I would think that if the main components appear to be decent (PTO shaft, gearbox, pulleys and bearings), then there is no reason why it wouldn't be worth a try - if you're in the market for a finish mower. It's probably just a little of half price of any other new units that I've seen.
That being said, if the gearbox shreds, the bearings toasts, the blades fall off and can only be purchased from a store located in Inner Mongolia that's only open on 5th Tuesday, then maybe it's not worth anything!
Good luck and take care.
/ HF mower? #11
I read this quote for the first time earlier today on a construction forum and think this would be a good time to share it. "Buy the best and only cry once".
Man, have I bought some junk and cried more than once over the purchase.
/ HF mower? #12
:laughing::laughing::laughing::laughing::laughing: LOL!!!
/ HF mower? #13
Thanks for chiming in Dargo! You're the real expert on this very subject!!! :laughing::laughing::laughing:
/ HF mower? #14
Like that quote...:thumbsup:
/ HF mower? #16
on the other hand... do you like to pay more than you have to?
here's a case and point.
12? ys ago I was in the market for a pickle fork to do some tie rod end work on my tractor.
napa.. 19$ looked good.. chrome or at least bright zinc finish.
HF 3.99$ zin.. not high polish.. more of a matte finish. similar look / dimensions.
I bought 2 of the hf ones.. cost me something like 8.50$
I still have both of them. and the've popepd tie rod ends and drag links off of most of the things on my property now.
end one the 'main' one i use is mushroomed a tad, making it? 1/4" shorter.
has some gouges on the fork area. fork actually bent out wide once and I rebent it say.. 5ys ago. the backup has been lightly used for minor prying tasks.
both are still serviceable.
so.. I saved over 10$ getting 2 of them... at this rate.. the first one might actually wear to an unuseable state in 5ys... then i'll have to start using the other one... if I get 15ys out of it... hmm... I'd say they don't owe me anything.
I'm sure the 19$ one would have been fine too... just cost nearly 5 times as much to do the same work...
Now that's a BARGAIN! ;)
( yes.. I know you have to sift thru the jink at HF.. everybody knows that. )
soundguy
/ HF mower? #17
I've mentioned many times about the difference between "good" and "good enough". It depends alot on your application. I bought two sets of HF wrenches about 12 years ago, and told myself that if I could keep up with them for a couple of years, I would buy some "good" wrenches. I've not only kept up with them for 12 years, but used them on a regular basis, and decided that I don't need to buy "good" wrenches, because my "good enough" wrenches are indeed good enough for my needs. Would that be the case for a professional mechanic - maybe not?
Of course, my $20 wrench sets and Soundguy's $4 pickle forks are a little different than a $375 mower. However, if I were in the market for a finish mower I wouldn't pass it by without a thorough look. HF is a crap shoot, but they do have some pretty decent stuff and good prices in with the junk.
/ HF mower? #18
I am a Harbor Freight fan I have several tools in my WW shop that have done fine for almost ten years now. I find that frequently the things that they sell are exactly like a lot of imports, just at a lower price. Comparing a $400 new mower to a $400 used mower might not be as much different as you think. Comparing a $400 new mower to an $1800 mower is a whole different animal.
/ HF mower? #19
Download the pdf from the web page and check it out.
No breakdown of the gear box, if something as cheap and easy to replace as a seal goes it is going to become more work to find it than R&R.
It does look in the picture like the gear box has a stamped back cover and from the pdf a cast front cover. There better be a real good way to keep the front cover in location for gear life. And the Chinese aren't real great at tight fits and locating on their cheap stuff. Without a breakdown of the gear box (and my guess at the stamped back cover) I've got to wonder how the ring gear is supported, two front bearings?
The blades drive by 2 V belts, who knows how wide. They adjust by sliding the gear box instead of a spring tensioner. If one breaks or stretches they will need to be replaced as a matched set. The belt covers are a bunch of bolted together pieces of sheet metal, it won't be a quick adjustment.
I've never ordered repair parts from HF so if someone has it would be nice to find out lead time. Something as simple as blades could be a hassle if it takes a couple of months to get them. A bearing would mean the mower is down. I would look at it as a throwaway. If something goes wrong after the warranty it will probably be more hassle to fix than find another one.
IMHO You would be better off finding a decent used one. If you have time to look the price won't be much different.
/ HF mower? #20
Well I said it before and I will say it again. A guy down the road bought one. Its basically a copy of my Caroni. His is the 6' one and he has mowed 4 acres about 30 times a year with it for 4 or so seasons now. I know him very well and he greases it a few times a year and that is it. He changed the gear box oil after the first season and has had no issues. I know he paid $800 so this is a steal.
As for getting parts from HF, I had to once and its been 7 years ago or so but I do not remember it being a issue. I know it was free and they shipped me a whole assembly.
I would take the risk for that price. It has to be as good if not better than the $1000 I spent on a King Kutter back in 2003. Now that was a mistake.
Chris
2005 BOBCAT 323J EXCAVATOR (A64279)
2005 BOBCAT 323J...
2015 Jeep Patriot Sport SUV (A61574)
2015 Jeep Patriot...
2007 Chevrolet Express 2500 Cargo Van (A61573)
2007 Chevrolet...
Champion Vibratory Roller (A60462)
Champion Vibratory...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63118)
2006 Cadillac GM...
