need advice to install grapple
/ need advice to install grapple #1
stormpetrel
Gold Member
Block Island R.I.
ym2210D
I ordered a grapple for the Koyker 120 on my Yanmar 2210D. I'm a very new tractor owner & have zero hydraulics experience; want to get it right the first time. I am including two pics of the loader valve to see if it's able to have a power beyond fitting added. I want to include quick connect fittings, so I can unplug the grapple and run another implement (I'm thinking log splitter). I believe the grapple has 3/8" fittings.
I need to know what type of valve to buy to operate the grapple, how (and where) to tap into the loader valve, and whatever else I need to buy in the way of hoses, fittings, etc.
Thanks in advance for your help. You will have a great feeling after helping the (hydraulically) retarded. Me.
Steve
/ need advice to install grapple #2
It seems you have an open center with power beyond (or able to convert to it). Look on page 25 of the manual... top of page, "out (tank)" I did not see a third line (low pressure return) from your valve... is there one? (didn't see in your photo - or missed it...)
http://www.koykermfg.com/images/koyker-manuals/120.pdf
It this is the case, it might not be too different from the one I just did... (I did 3 valves but it's the same if you only wanted one).
Confirm that this is your loader model, too...
My write up: http://www.tractorbynet.com/forums/...7948-instructions-add-extra-spools-l2800.html
Yep, 120 is the model. I don't know if the fact that mine is two lever, and not joystick style, makes any difference?
So, the port that the power beyond sleeve goes into is covered by the valve mounting plate? Is that how you see it? I have no idea about the low pressure return hose........:eek:
I just read your write up........it helped me some, but I'm still considerably confused. Essentially though, won't the grapple cylinder be fed through the power beyond (and it's valve/spool) and then need to return to the hydraulics reservoir/tank? If that's right, then I'm on the way to better understanding this.
Now just need to narrow down the parts/accessories I'll need.
Thanks for the help........I'm really looking forward to getting this done.
Look at this video from Everything Attachments:
Tractor 3rd function kit
They sell a kit for setting up a grapple. Might give you some ideas.
That was very helpful, and exactly what I had in mind as far as being able to remove the hoses going to the grapple and plug another attachment in.
The whole handle idea confused me severely however:laughing:. I envisioned a single spool valve mounted above or on the side of the loader valve. Also...the kit from everything attachments is $700!!!!!!!! OUCH!
I don't know if I want to pay for that fancy finger-controlled rig. Does anyone have one installed on their tractor? Feedback??
the replies I've gotten so far have been a great help. It's nice not to feel like I'm doing it alone!!:thumbsup:
/ need advice to install grapple #6
This might be correct... (I'm very much a nubie when it comes to hydraulics) There was someone, that talked about using the power beyond to connect into a valve... but I don't know anything like that... The #2 circle might be the actual power beyond do hicky thingie you'll need ????
/ need advice to install grapple #7
stormpetrel,
The PB port is on the right with the large hex plug. When you get the PB sleeve, remove the plug and screw the PB sleeve in.
/ need advice to install grapple #8
I hadn't checked the price for the kit. That is steep. I literally know zip about hydraulics...other than they let you do some really cool stuff.
I did get the rear SCVs installed on my JD 3038e. I was thinking they would be fine for running the grapple until I saw that video. But apparently you need the kit to upgrade your loader stick to have a true third function. Am I wrong?
Whatever you decide to do, please let us know.
/ need advice to install grapple #9
FWIW...I have seen valves that do not have PB...but do have both side and face ports for different hose configurations...
stormpetrel,
Thanks, very helpful.
So: from PB sleeve, to grapple valve to grapple, back to tank? Am I even close? :confused:
I think the power beyond sleeve is what gives true third function capability (anyone?). I suppose that would leave some room for doing it with a separate valve, especially since I have a dual-lever loader control.
Thanks everyone for all the ideas and help......keep it coming!!!!
/ need advice to install grapple #12
The fluid from the grapple out port should go back to the 3pt. The tank port on the FEL valve should go to tank, as this is now expended fluid from the cylinders.
Scroll down to page two for illustrations.
  • PRINCE=Series20InstS.pdf
/ need advice to install grapple #13
The grapple valve that you purchase, should have full pressure limits on both the input and output ports, as the 3pt circuit may develop high pressure.
Alright....that was WAY helpful, and just what I needed to gain some kind of half-witted understanding of how she works. I think with just a little bit more help I'll be able to do this........:thumbsup:
Thanks so much, I was not gonna get very far on my own with this. I'm still interested to hear any advice; especially from anyone who has the third function kit from everything attachments installed on their machine.
Steve
/ need advice to install grapple #19
Yes....but I don't know what that means:ashamed:
Detent means that the valve will stay in the detent position until you set it to neutral, and probably is not a good valve for grapple operations.
Did you want a manual valve or solenoid operated valve using a switch on the handle?
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2003 Dodge Ram 1500 Crew Cab Pickup Truck (A64556)
2003 Dodge Ram...
2025 Auger Bit Skid Steer Attachment (A64553)
2025 Auger Bit...
2011 TORO SP5040 MOWER (A66091)
2011 TORO SP5040...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A64553)
2018 Takeuchi...
