What does this lever do?
/ What does this lever do? #21
New guy here! I have found that going from 4 to 2 wheel drive is not difficult if you just inch the tractor forward or reverse and as it drifts back the lever slides in very easy. i only have 7 hours on my CK30 but have fallen in love with it. my only complaint is I wish it had more leg room, I am not that tall 5'10" but my knees get to hurting after a couple of hours of loader work.
/ What does this lever do? #22
I'm not trying to be a wise guy, but is the seat adjusted all the way back? I'm 5'10 and have spent the whole day on my tractor without problem.
/ What does this lever do? #23
You got 1 wd,next with differental locked you got 2 wd,than with the lever in right spot,you got 3 wd,you never have 4wd,,and don't use that differental lock when your turning,just use it if you need both rear wheels to turn for a short straight spell.
My owners manual is pretty good,and also,you can buy a more detailed shop manual.
You never have less than 2wd unless 1 rear is in the air ... then diff loc gives 1wd or 3wd. When in 4wd you never have less than 4wd if all wheels are touching. If a front comes up youre down to 2wd. If one rear comes up while fronts are down you have 0wd, but engaging diff loc will then give 3wd. If both rears are up while fronts are down DL will give 2wd.
larry
/ What does this lever do? #24
yes the seat is all the way back any more and I would be on the little tool box, I think this is just something that i will get used to.
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
(8) John Deere Tractor Weights (A64119)
(8) John Deere...
(2) 380/85R28 TIRES W/ 10 LUG RIMS (A64280)
(2) 380/85R28...
2006 Hummer H3 4X4 SUV (A61574)
2006 Hummer H3 4X4...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A65053)
2018 VOLVO SD75B...
