Tires water out of rear tires
/ water out of rear tires #1
fotoman
kioti ck25
I just went to fill my rear tires of my ck25 and found water in them i bought this tractor used so no idea about someone putting water in them how can I remove the water in them i also have a backhoe on it as well could i use the legs to jack the rear tires to drain or use a shop vac to suck the water out thru the stem
/ water out of rear tires #2
/ water out of rear tires #3
Jack the tractor (jackstands under the axle), pull the valve cores and rotate the valve stems to 6 O'Clock. Let it set...it's going to take a while.
However, there's no way to vent those tires unless you break the bead.
got water out but now I broke the bead on the tire need to call local tire shop for home fix has anyone tried to do this at home should i take the tires off the tractor and bring them in any idea on cost:)
/ water out of rear tires #5
Well,now since you're into it,you need to get them refilled with something that won't freeze,really helps in several ways.
i was draining the tires to get the water out since i have a backhoe for weight why would i refill the tires
/ water out of rear tires #7
I almost hate to tell you this, and I have never done it. but You-tube is full of how to reseat the bead on tires. it involves a small squirt of wd-40 and light it from a distance.. POP/Bang, it is reseated.. in 2 seconds total time.Then air it up. I am sure if you put too much wd-40 in, you are in danger of losing your head or something else important. Use at your own risk.
James K0UA
/ water out of rear tires #8
Well,if you're going to leave the backhoe on...all the time,,maybe you won't need to worry,,,but loaded tires also help side stability,,say you're on a little sideways type slope moving,you move your boom maybe in downhill direction,that uphill loaded tire might be nice:D,,,there,thats two reasons.
/ water out of rear tires #9
You're sure it was pure water and not calcium chloride/water?
The reason I ask is I have seen people inquire how to tell the difference.
2016 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
10 Safety Systems Barricades (A59317)
10 Safety Systems...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
