Rotary Cutter Winter implement storage
   / Winter implement storage #1
jtheise4
SE Michigan
Massey Ferguson 1643 & Allis-Chalmers D14
Its that time of year in Michigan to put away the rotary mower for the year. Unfortunately, I don't have room in my garage to store my bush hog, so I have it sitting outside on cinder blocks. My question is, should I place a tarp over it or just leave it exposed to the elements? How does everyone else in this situation store their equipment? Thanks.
   / Winter implement storage #2
Outside on the ground, no tarp. ...but I did not spend much $$$ on them since they're all used. When I bought them, they were outside unprotected. Really depends on how you treat YOUR equipment.
   / Winter implement storage #3
I store everthing with a gear box inside....and try to oil or grease things like disc blades and get em up off the ground. Cover 'em is better in my mind....but I use some tin or a piece of scrap plywood which allows air cirulation yet keeps the snow and weather off. I suppose a tarp is good too?...if some air can circulate? I would take any PTO shafts off (if its easy to do) and store them inside. Cover any slip-clutches for sure.
   / Winter implement storage #4
Everything is outside on the ground in the weeds. Even my post hole auger is on the ground. Never caused any problems.
15 attachements and you have room to store them inside?!?! WOW!!!! I am very jeleous. I'm hoping to build a new building on my property sometime in the next couple years, but that doesn't do me any good now.
   / Winter implement storage #6
I grease / oil everything up good and store them outside with no tarps.
Tarps make a great place for rodents to live, I all ready have enough problems with that.
E/S
   / Winter implement storage #7
E/S
Not to mention condesation (but you may not .....) :laughing:
   / Winter implement storage #8
I moved my york rake and the box channel frame was filled with water. Glad I found it before old man winter did. I set it on blocks, tipped the other way.
   / Winter implement storage #9
I place on pallet so unit won't sink into mud come spring,also cover enough for air movement.
   / Winter implement storage #10
Well....the only things with a gear-box are my Tiller, Rotary Cutter, Stump Grinder, Grapple (cylinder), and Cyclone Spreader (and a few smaller items). The rest goes outside: Disc(s), Rake, Cultipacker, Lime Spreader(s), Plow, etc. I wish I had more space inside....but at some point......the storage space would cost more than what I have to store. ;) :laughing:
I have a good shed.....and its two years old now......and its too small. :(
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
2016 Chevy Silverado Z71 4wd 5.3L V8 (A56438)
2016 Chevy...
Tanker Trailer (A59230)
Tanker Trailer...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
2016 Nissan Altima 2.5 Sedan (A59231)
2016 Nissan Altima...
2006 Ford Explorer 4x4 SUV (A59231)
2006 Ford Explorer...
