Oil & Fuel 4020 injector pump?
/ 4020 injector pump? #1
John Deere 4020
John Deere 4020
Have a early model JD 4020 starts but stalls out immediately. Wonder if it could be injector pump? if not what could it be?
/ 4020 injector pump? #3
Sounds like air in the system. I doubt it is the injection pump. Check filters, restricted line, air.
Do a flow check to the filter and at the IP.
We have replaced fuel filters, brand new fuel pump, purged lines and still same thing.
/ 4020 injector pump? #6
Try removing the timing window on the injection pump. It is a rectangular cover about 3/4" X 1 1/2" held on with two small screws. When you remove the window(cover), see if there are any black coffee ground appearing stuff in there. If so then the pump is in need of repair. While the window is off try starting the tractor and see if it will continue to run. (put a bucket under the pump area first, fuel will leak out) When the cam ring in the pump fails and produces the coffee grounds material, it clogs the return fitting or line and causes too much case pressure in the pump, causing it to shut off. Allowing the fuel to leak out of the timing window will allow it to continue to run. jdemaris has excellent threads on how to repair the pump yourself if you desire.
Sakai SV505 (A60462)
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2022 BOBCAT T870 SKID STEER (A64279)
2022 BOBCAT T870...
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A61573)
2004 Dodge Ram...
2003 Freightliner FL60 Ambulance (A61573)
2003 Freightliner...
