Tires Tires and rims for MF 65. Carb question too.
   / Tires and rims for MF 65. Carb question too. #1
artie40
Massey Ferguson Model 65
I just had a rear rim crumble where the air valve is located. A piece the size of a soup can lid disentegrated when adding air. I am having trouble finding a rim for the tractor. The tire size is 14.9-28. There is a matched set on the tractor. The rims are the expandable type. Any suggestions? I am in Massachusetts. I have one Massey Ferguson dealer looking (Whately, MA, NH and Maine) but am open for suggestions. I'm guessing I should buy a pair of rims and tires since they seem to be originals (1963).
Also, The carburator started running best at 1/4 choke. I've cleaned it, the fuel line, filter and removed all sediment from the tank. Suggestions here would be helpful as well.
Thanks,
Artie
   / Tires and rims for MF 65. Carb question too. #2
Thanks,
Artie
What type of center is the rim I know where a few are but need to know which style you have.
Jeremy
   / Tires and rims for MF 65. Carb question too. #3
The center could be the old disck screw type with slots in the rims or flat and direct bolt on spin out rims.
Jeremy
28x12 4 Rail Power Adjust
This is what I found. (see Hey wheel link above) A Neighboring farmer said I could use a 28 X 12 or 28 X 13 rim with the 15.9 tire. I confirmed this with my local tire guy. The center disk is held to the rim rails in 4 locations and locked on one rail only. The center disk was held to the axle with 8 lug nuts on 5/8" diameter studs.
Question: Fill tires with Calcium again? Or is there another alternative "now a days"?
Thanks.
I meant 14.9 - 28 on the tire size NOT 15.9.
   / Tires and rims for MF 65. Carb question too. #6
I had new tires put on my 65 20 years ago and had the same problem. At that time we were able to weld a patch on rim and then grind it down, 20 years later and no problems although I was taking the fluid out anyway. Also rebuilt my carb. at same time marvel schebler TSX695 made a world of difference.
Thank you for tire and rim advice all. Carb work starts next.
2000 KOMATSU VALMET 860.4 FORWARDER (A51222)
2000 KOMATSU...
3 pt Rolling Basket & Harrow (A50514)
3 pt Rolling...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A51222)
2016 VOLVO VNL300...
2025 FREIGHTLINER M2 NON CDL BOX TRUCK (A51222)
2025 FREIGHTLINER...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
