Mig opinions
/ Mig opinions #1
timswi
Super Member
Beaver County Pa
Kubota BX23 TLB, Kubota RTV1100, Kubota Z724 & Polaris RZR 900 Trail
I'm thinking about buying a new 110v mig. The one I have is a budget version that I bought 15 years ago. It has served me well, but it takes some work to put down a nice bead with it.
I've used Millers...They seem to do a nice job. Also looking at Lincoln.
Any opinions on the 2 brands. Will be using gas with either.
The one upside to Lincoln is that the parts seem to be more available. Millers are sold at specialty shops around here.
Thanks.
/ Mig opinions #2
115 volts tell little, what is the model and current at the published duty cycle, not the max current.
/ Mig opinions
I don't have the models handy. Just looking for a multi-purpose machine that will be used mostly for auto body work..18 ga and less most of the time. Otherwise general welding south of 1/4 inch. Have a stick welder to deal with the heavy stuff.
Suggestions are welcome.
/ Mig opinions #4
Both are top of the line brands,as far as that goes,,,but who knows when buying a 110 volt.
/ Mig opinions #5
Both machines would be great. If you want to save a few dollars go with a Hobart Handler 140. Its a Millermatic 140 minus the purge option. Ive seen the kits around here for about 600 Canadian. I have Millermatic 140 and I love it. I also Have a Lincoln Precision tig 225, a powermig 215, and Ranger 305 g. Im not brand loyal but for 110 machines I prefer what Miller/Hobart has. And if you aren't aware Hobart and Miller are like GMC and Chevrolet.
/ Mig opinions #6
I have a Lincoln 135 that I found on CL, only slightly used for about 1/2 new price w/o tank). I've been very happy with it for light work! Like you, I have an old stick that I'm very familiar with for any thing over 3/16" or so. ~~ grnspot110
/ Mig opinions #7
I got a miller 135xp. Been a great machine...BUT l should have bought bigger.
Id save up and get either a MM 180 or 212. My dream machine would be a 252
/ Mig opinions
Didn't think of Hobart...Thanks. I kinda knew they were pretty much Millers. Thanks for the reminder.
/ Mig opinions #10
You don't say what your buget is, if your spending limit allow's look at some of the smaller 220 machine's.Found a lincoln sp180 at local TSC a while back on sale,it does great work for the money, not a lot more than some of 110 machine's.If you get up to 1/4" and 3/16" steel the 220 is great.
/ Mig opinions
I'm mostly sheet metal with the mig...But if 220 can do both, that would work.
Don't really have a budget for one. If it's worth it, I'll buy it. The 110v versions seem to run 500-650 or so.
110 is just a little more convenient.
/ Mig opinions #12
I have a Miller 180, and a 135 before that. Both great machines, but I actually liked the 135 more. It is capable up to 1/4 inch material, with proper prep work. I found that thin metal required short bursts or burn-through was a problem. 2-3 second stitches cured that.
Miller parts are a little harder to find, if you have a local "pro" distributor it won't be a problem.
Sean
/ Mig opinions #13
I had a Lincoln 100, worked fine but I have two friends who have the sp125 that I used plenty of times until i bought my 255. The 100 has 4 voltage settings while the 125s have variable setting. After using both I would only get a welder that has variable voltage settings. But it's been years since I've looked at smaller MIGs so things could have changed.
/ Mig opinions #14
Keep your eyes on c-list for older 220 units. I personally dont like some of the newer welders with all the fancy digital readouts and stuff. I bought a 225A 220V linde a few years ago for $600. Linde was bought by esab which is another good brand like miller and lincoln.
IMO the bigger units weld nicer, even on smaller stuff. And the duty cycles are higher and you CAN weld the heavier stuff without having to get the stick out. If your primary work is sheetmetal, the larger units will do just fine, but If you but used, it will more than likely be set up for .035 wire. You will probabally want to change the tip and other necessary parts to run .023 wire or .030 wire. But yes the will weld the smaller stuff just like the 110 units and IMO they weld them better.
/ Mig opinions #15
Last year I bought a Lincoln 180C 240 Volt Mig welder on sale. I have been satisfied with it so far. The welding range is 24 gage -3/8 single pass (I am not positive on the 3/8) and up to half inch with multi pass. I am no expert welder but last year I welded a neighbor's rusted off exhaust on his van back together and it held for 7months or so, till he got a new one. I have also welded thick stuff but I don't know how strong that it is.
/ Mig opinions
Thanks guys...I starting to lean a little towards the 220v. Hadn't really given those a thought before. I'll have to check a couple of those out.
/ Mig opinions #17
timswi,
If you are looking at 220V, our Everlast MIGs can go toe to toe with any on the market, with heavier built PWM controlled wire feeders (no plastic), spool gun capability, digital read outs, and inductance control with heavier, and nicer Binzel gun. They are inverter based and weigh typically less than half their transformer counterparts in the major name lines, consume less power, have much higher duty cycles and have much less spatter. Price is less as well.
If you don't have us in mind, I can understand your sentiment, but its worth looking at.
/ Mig opinions #18
Mark how much inductance control does your machine's have? Scale of what to what?
Who ever invented inductance control should get a big juicy jelly donut!:laughing:
I love how much control I have over the puddle with it!:cool:
/ Mig opinions #19
Shield Arc,
From a scale of 0-10. lol.:laughing:
I typically run it about 3/4's full throttle.
I'd give them a whole box of Krispey Kremes with raspberry filling.
I can pretty mimic any mig on the market and then improve upon that with my own settings. (For Miller, I crank way left...)
IF you've never had it, its the best tool a MIG can have, unfortunately, you have to get BIG migs to get this feature with other brands. So many people suffering with underperforming migs and don't know it....sort of like eating only a diet of unseasoned broccoli and being told its fine dining.
/ Mig opinions #20
Yeah, you know I never really thought about it, why don't all Mig machines come with it? Expensive to add?:confused:
I love how you can dial it down and get a really wet flowing puddle, or crank it up and get a real dry puddle for doing verticals or overhead. It should be a law, all Mig machines come with it! :laughing:
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
2018 CATERPILLAR 573D FELLER BUNCHER (A65053)
2018 CATERPILLAR...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
