L3700 scraper blade size
/ L3700 scraper blade size #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
Does anyone run a 7' scraper blade on a L3700 series tractor. I was wondering if I can swing it all the way around without taking it off?
Thanks
/ L3700 scraper blade size #2
I've got one on a 2250 and no way can I turn it around without removing it first. It might be possible with a different blade that had a longer tongue.
/ L3700 scraper blade size #3
I know this might not help but I use one on my L3430 and am able to spin it all the way around when I lift it with the 3ph. My tractor is 35 hp and I think it is about the same size as yours.
I am thinking the L3430 is on the same frame as a 3700 but am not positive... Any trouble pulling it or using it? I want it mainly for doing snow and ditches. I have used a 6' on it without a problem and my dealer has a 7' cat 1/Cat 2 70HP blade at a good price so I was looking at getting that one.
Thanks for the info!
/ L3700 scraper blade size #5
I have a 7 footer on my L4400 and I think that a 7 footer on a L3400 would be to much. I wouldn't want any bigger on my machine and it is a frame size bigger. The bigger a blade is the farther it sets back. I would think a blade with offset and tilt would better serve you.
What dealer are you refering to I have been to most in this area?
/ L3700 scraper blade size #6
It's going to depend on the tongue length of the 7 foot blade. It doesn't really matter which tractor it's on, if the ends of the lift arms are in a "standard" position, the blade will clear if it's designed properly.
Sean
/ L3700 scraper blade size #7
I have a woods and agree that it is tongue length that decides if you can flip it or not - I can on my B3200 as long as I only raise it an inch ot two off the ground and have some slack on the 3pt chains.
On a side note - I have found the scraper blade is really not all that helpful - I am sure they are in certain applications but I wish I had never bought mine and got a box blade instead. Keep in mind they don't weigh all that much so they don't "scrape" like a dozer blade. They mostly just skid across the ground. Again - I am sure there are great applications for them like scraping manure off a concrete barn floor but don't think you will be able to "angle" the blade and have it cut a swell into anything. Also, longer blades put lots of torque on the center piece and you can break it pretty quickly.
I know there are a lot of smart people here with different opinions but it might be worth it to post your application and see if people think a blade is the way to go - Hate to see anyone buy the wrong piece of equipment (repeat my mistake).
/ L3700 scraper blade size #8
I use a 7 footer med duty on an L2500 and I can swing it around if I raise ti the right height. I do not find it too much for my tractor so I wouldn't hesitate on an L37. (Remember you almost always have it angled which lessens the pulling resistance, unlike a box blade where you are always pulling the full width. As far as usefulness in the last post I beg to differ. They both have their uses and at times I use a box blade and on other jobs I use the backblade. Going slow with an angle and the right pitch from the toplink and it does a decent job of cutting gradually into virgin earth. Just perfect for creating mild swales. Of course a med duty is fairly heavy. A light duty wouldn't do as well.
/ L3700 scraper blade size #9
When purchasing a rear blade, measure how long the boom is from where the 3pt attaches out to the pivot point where the blade angles. If 1/2 of the blade length is shorter than this measurement then the blade will turn 360* no problem. On the less costly blades, this can be a factor and those are the blades that have to be off of the tractor to be able to turn the blade around 180*. Just one of the things that should be considered when purchasing any of these types of implements. ;)
Seen it over at Straton - it looks nice and is rated to 70hp. Im just not sure I want to move up to a 7' blade. If it was a 6 foot I would of bought it> I already have a box blade but really like the scraper blade for doing snow in the winter and I wanted the tilting side shifting style so I can also use it for cutting ditches (thus the reason I want a heavy duty model).
Thanks for the info
Dex3361 - what town are you from? Im over in Hurricane
/ L3700 scraper blade size #11
I use a blade for snow and light grading. Since I got a box blade I don't use it much except for snow. Have you looked at Stephens tractor in Jackson Co. they usually have a good selection of scraper blades?
/ L3700 scraper blade size #12
You will be a lot better off with the 7' blade. Remember that you cut a lot narrower path when the blade is angled.
/ L3700 scraper blade size #13
I run a 7', medium duty KK on my 32 hp L3240. It's a very versatile attachment, but it requires more skill and patience than I sometimes have to do better than tear up whatever it is I happen to apply it to. Mine does great service moving snow and I'm starting to develop some skill with it moving and contouring soil. I find I have to be constantly adjusting the height - it's definitely not a set it & forget it affair. I really wish I had T&T - that would make it so much more useful.
Inside tire spacing, aft distance from rear tires to 3PT hitch pins, aft distance from 3PT Pins to Blade and moldboard height from ground to 3PT hitch pins are also part of the equation as to whether or not it will turn 360 degrees on your machine.
Best bet is to see if you can try before you buy it.
-Jim
2019 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A64556)
2019 Peterbilt 579...
2005 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A64194)
2005 Chevrolet...
2017 Ford Expedition SUV (A64557)
2017 Ford...
PALLET OF HOG CREAT PANELS (A64278)
PALLET OF HOG...
2019 AUTOCAR XPEDITOR TRASH COMPACTOR TRUCK (A63276)
2019 AUTOCAR...
2025 IRANCH Tire Changing Machine (A64194)
2025 IRANCH Tire...
