L3700 scraper blade size
   / L3700 scraper blade size #11
I use a blade for snow and light grading. Since I got a box blade I don't use it much except for snow. Have you looked at Stephens tractor in Jackson Co. they usually have a good selection of scraper blades?
   / L3700 scraper blade size #12
You will be a lot better off with the 7' blade. Remember that you cut a lot narrower path when the blade is angled.
   / L3700 scraper blade size #13
I run a 7', medium duty KK on my 32 hp L3240. It's a very versatile attachment, but it requires more skill and patience than I sometimes have to do better than tear up whatever it is I happen to apply it to. Mine does great service moving snow and I'm starting to develop some skill with it moving and contouring soil. I find I have to be constantly adjusting the height - it's definitely not a set it & forget it affair. I really wish I had T&T - that would make it so much more useful.
Inside tire spacing, aft distance from rear tires to 3PT hitch pins, aft distance from 3PT Pins to Blade and moldboard height from ground to 3PT hitch pins are also part of the equation as to whether or not it will turn 360 degrees on your machine.
Best bet is to see if you can try before you buy it.
-Jim
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
CATERPILLAR 48" QUICK ATTACH FORKS (A51242)
CATERPILLAR 48"...
Wooden Barge Wagon (A50515)
Wooden Barge Wagon...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
