SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,613
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
I have needed to update my input on this thread for some time to avoid some possible disappointment. As described, the former [blocky shaped] Zantrex Inverter 1000 was bullet proof for me thruout yrs of use and abuse. Finally 2 of my 3 were burned out when I loaned the tractor they were on. Non owners are adept at cutting cords and this does the inverter in. I replaced with the new style [rounded corners] Inverter 1000. As for power it is noticeably inferior, but ok. As for robustness it is very poor by comparison to the old. In the same exact duty I have had 2 just go dead in the last yr - no abuse/cut cord etc. It may be they would last longer in a more sedate environment.:confused2: I cant recommend them tho like I could their predecessor. :thumbdown:Here is text of my posting in a previous thread regarding experience with inverters on tractors.
I have direct experience with running Remingtons 14" Limb and Trim on both Xantrex and Vector 1000W inverters. This has turned out to be a long term compatible combination. The saw is rated at 8.0A, 120VAC, which means it requires around 960W at load. The Xantrex has been mounted on our BX1500 hood for years and the Vector is on the Kub 2550 also long term. The invertors pull about 100A to run the saw so DC wiring must be good. This is more than the tractors alternators put out but with the engine running even on the little one you can do several continuous minutes of heavy cutting or 20-30min limbing before the inverter cuts out due to low supply voltage. I have had trouble with other inverters in these useage conditions. These are mechanically and electrically robust. Ive had no problem with the startup surge except when I had a poor DC connection. You can spot check those by running a 500W shoplite or other substantial load and measuring across each DC connection with a digital Voltmeter. This will allow you to compare the quality of each individual connection. You want very low voltage readings like 0.1V or less at this 60A load. If not, the higher loads inherent in startup will cause the inverter to kick out because it isnt getting high enuf supply voltage.
I love these things - lets my wife use a chainsaw. She cant pull enuf to start a gas.
I paid $70 for the Xantrex inverter at costco. I think battery powered tools get expensive more quickly than an inverter set up, and they limit you to less power and less run time. Its nice not to worry about a cord, but the tools weight with battery adds up.
Larry
larry
