Loader I need a Loader!!!
/ I need a Loader!!! #1
Part timer
Member
Kentucky
2008 jinma tractor king 254
Hi guys I have a 08 Jinma Tractor King 254 and I am in need of a loader for it. I am considering building my own loader because of the cost savings, but I have a few questions for the Pro's!!
1. Has anyone built their own loader?
2. Any issues during or after the build?
3. Any tips on building?
4. Any recommendations on buying a new or used loader?
Thanks.....Chris
/ I need a Loader!!! #2
/ I need a Loader!!! #3
Thanks.....Chris
Tommy's right. By the time you add up the cost of all the parts and materials (pins, bushings, hydraulic controls, hoses, cylinders, steel tubing, welding rod/wire, oxy-acetelyene, engineering costs, etc.) you will be miles ahead by purchasing a pre-built unit, or seeing if there is a pre-fab kit out there.
:D
I have gotten quotes on materials and I think you guys are right I could probably save anywhere from $500 to $800 not including building cost such as welding materials and what not plus labor..
Tommy could you send me a quote on a koyker 140 shipped to henderson ky area.
Thanks.... Chris
/ I need a Loader!!! #5
I have gotten quotes on materials and I think you guys are right I could probably save anywhere from $500 to $800 not including building cost such as welding materials and what not plus labor...
And with all due respect, unless the job looked absolutely professional, it would detract from the value of the tractor. Aesthetics are important. Question: Were you going to have someone engineer it for you, or just leave things to chance?
/ I need a Loader!!! #6
Besides Tommy several other places you may want to check into are Rural King: I think they were selling several versions of compact loaders for Jinma & Foton tractors. Farm-Pro and perhaps Bolton power & Equipment is closer so shipping might be easier or a drive over to pick up.
Mark
/ I need a Loader!!! #8
I'm only about an hour south of you, and there's an independent tractor & equipment mechanic just down the road from me. Worked half his life repairing mine equipment. Retired some years ago, and fixing farm stuff in a 1 man shop to augment his Social Security. Last time I was in there he had a used loader the right size for your Jinma. Looked to be in pretty good shape. About a four footer, came off a Kubota or a Kioti I think. Pretty sure whatever price he asks will include installation. I can see if it's still there if you'd like (?)
//greg//
/ I need a Loader!!! #9
I have had a Coldwater FEL on my 284 for several years and am pleased with it. It has done everything that I wanted. You might check out:
Coldwatertractors.com
RonJ
//greg//
If you don't mind check on it for me or if you have his name and number you can message it to me either way I would appreciate it..
2016 TAKEUCHI TB216 EXCAVATOR (A62129)
2016 TAKEUCHI...
2015 PETERBILT 367 WINCH TRUCK (A60736)
2015 PETERBILT 367...
2013 MACK GU713 CAB AND CHASSIS (A60736)
2013 MACK GU713...
2018 Ford F-150 4x4 Pickup Truck (A61568)
2018 Ford F-150...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
2025 12v Fuel Pump (A61568)
2025 12v Fuel Pump...
