VHF Gain Antenna
/ VHF Gain Antenna #1
txdon
Super Star Member
Central Texas
Kubota M6H-101
I am receiving an excellent signal from all of the HD TV UHF stations 18 through 54 over the air. FOX-7 is a VHF station and I am not getting a signal. (I received it perfectly before it switched to HD.)
I contacted FOX-7 and they said I need an antenna gain for VHF. Has anyone had a good experience with an antenna with a gain for VHF.
(I live about 50 miles East of Austin TX)
Thanks!
/ VHF Gain Antenna #2
A large Channel Master style antenna works good to receive VHF. A good amplifier between the antenna and the receiver may also help. By the way, there's nothing different about an "HD" antenna. It's still receiving the same frequencies.
Pick up FREE Digital TV with Channel Master digital HDTV Antenna CM-3671 for the best TV antenna reception, this is a UHF VHF antenna which is good for weak to strong signal strength areas. This is our longest range tv antenna
http://www.amazon.com/Channel-Maste...iewpoints=1&sortBy=bySubmissionDateDescending
/ VHF Gain Antenna #3
I have large Channel Master antenna - it has the big elements for VHF and the small "yagi" V up front for UHF. Seems that most digital channels are broadcast on UHF but some are not. One example is channel 8 Dallas - I'm pretty sure it is VHF. The antenna is on top of a 50 foot tower and there is also an amplifier mounted on the antenna itself. I have a rotor to tweak the aim when necessary. Channel 8 was my worst channel (pixelated quite a bit) until they switched over the strictly digital - at that point it cleared up.
Even though my antenna looks more life a VHF than a UHF antenna it is doing a great job picking up the signal about 75 miles from those broadcast towers south of Dallas (I am north). If it was me I'd get an antenna that does a better job on VHF figuring it will do just fine for the UHF channels. And you do need an amplifier unless you are pretty close.
/ VHF Gain Antenna
No luck with re-scaning the channels or manually putting in 7, 7-1 etc.. Thanks for the antenna info.
/ VHF Gain Antenna #5
Check out Antennas Direct. I used them a couple of years ago when the changeover was in progress. Here in the Denver area they had temporary broadcast sites downtown while they built out the "mountain" site. Signals were a mess. Called Antennas Direct and they were very helpful in sorting out the equipment needed.
Jack
/ VHF Gain Antenna #6
In many areas, stations have moved their frequencies (actual channels) around the time of the change to digital. Most of my available networks moved up to the UHF band which is excellent since they are easier to recieve. Some stinkers have either moved or stayed in the high VHF band where you need a big goofy antenna to receive them. You can easily make a UHF antenna but the VHF guys are herkin big.
Some stations just quit broadcasting from a tower and moved to another tower.
/ VHF Gain Antenna #7
I am 60 miles north of Buffalo New York and am going through the change to digital. That means Canada, we are slated for the summer of 2011. I am preparing to pickup this week 24 feet more tower to increase my height to 64 feet. The digital converters have only been on the shelves for 10 months.
Craig Clayton
/ VHF Gain Antenna
I now have an indoor new HD RCA UHF VHF antenna (11"X11" square). Fox7 emailed back and said:
"Hello Sir,
Thanks again for your interest in FOX Programming. I would be happy to work with you and try to resolve your reception issues. I have tested a few of the antennas on the market and have found the Winegard GS1100 to be very reliable at VHF Frequencies. Judging from your distance I would also recommend at least 30 feet of antenna height."
/ VHF Gain Antenna #9
Wow, I wonder what he would think of my HF beam?:):)
I guess it is all relative;)
James K0UA
/ VHF Gain Antenna #10
I chose a CS2 [clear stream 2] UHF antenna for my cabin thinking I was gonna be high enough to reach the stations 35 miles to the west. Wrong! I should have gotten the CS4 which is similar to the one in the thumbnail above. I had to reach out 75 miles to the south. Amazing enough I am getting 7 channels depending on the amount of leaves on the trees and the wind. Daytime reception is spotty on some of them.
The bad part is I believed the UHF antenna hype about VHF 7 - 13 coming in on the UHF; well one of the major networks went back to VHF 6 and I can't get it. The major on channel 3 is really now using a UHF frequency and I get it when all the leaves are down.
They guys will be disaponted over no Monday night football as we don't get ABC at all and FOX only at night whenthe weather cooperates.
/ VHF Gain Antenna #11
This might not make sense to everyone but....
I've got to go about 60 miles to get all the major stations. They are all in the same direction (I'm in Efland, NC, they are in Clayton, NC). I use a UHF 8-bay like the K7LN thumbnail for UHF. It's in the attic of my two story house. I come down on a quad shield RG-6. I also ran power to the attic and have a pre-amp up there right at the antennae. At the high UHF frequencies, the cable losses are significant and a preamp at the antennae is good. By having it all indoors, I don't have the weather issues and lightning issues, and can service things easily.
For VHF, I have a single frequency beam (for channel 11) also in the attic. It has it's own amplifier on it.
So I have a coax for UHF and a coax for VHF. In the basement, I add another gain stage to the UHF (a On-Q/Legrand VM7640 from a box store, a good amp for indoor use). These work better than the Channel Master amps (less intermodulation distortion). I mix the two signals together with an Amateur Radio 2M - 440 splitter. It has substantially less loss and better isolation than a typical UHF/VHF splitter. You plug in UHF or N to F converters on it. The impedance mismatch is negligible and insertion loss is still lower than the typical UHF/VHF device. The two ports are well isolated enough that the amplifiers driven them don't interact.
So, I think an amplifier by the UHF antennae is very important given the cable losses. My attic is conditioned space, so I don't have to worry about cooking the amplifier and can use an indoor amp. It's really nice having the attic antennae and not worrying about weather and lightning. All very unique to me situation I realize. If you can't pull what I did off, I'd at least strongly recommend an amp by the antennae and an installation where you can get to the amplifier semi-easily to change out the amplifier from time to time. Seems like the outdoor ones don't last more than a few years. I used to use a UHF amplifier in an attic that was not conditioned space (read "real hot"), it would last a year or two before it cooked and needed to be replaced. Also be sure to use the RG-6 cable.
Even if you could drop down from the attic about 10-12 feet or put an amplifier at ladder height near the base of your mast it would be a win. If it was inside then you'd have the amp on the cable where it was in nice conditioned space, then continue to the end point (basement or TV room) and you'll do better. A typical run for this sort of stuff is about 50 to 75 feet, and you'll loose a lot of signal strength in that run. If you are not sure about all this, get the amplifier and play with it (extension cords to the attic, coax down through the house, etc.) and you can see if it will work or not. Last resort is an in line amp powered by DC over the coax, but with the cable losses it can be better than nothing.
Pete
/ VHF Gain Antenna #12
Thanks!
i think that square ant in the picture ie uhf only.
/ VHF Gain Antenna
As you can tell from the pictures below I have about 5' of insulated attic space (30 ft. to TV) and I also have an outdoor junction box with a tube to run cable (50 ft.) to the living room mounted on the brick on the side of the house facing Austin. I have a metal roof, will that eliminate attic installation?
I was hoping to get a smaller antenna (3') and a S mount on the wall junction box, but I don't know if that is workable.
Thanks for you help, I have a lot of research to do.
/ VHF Gain Antenna #14
I don't think that trying to receive through the metal roof will work. I have a metal roof, but it's a shed roof and I'm pointing out through the wall, not through the metal. So it comes down to how your roof is set up and where the transmitters are.
Even though the 4 and 8 bay (or bow tie if you will) antennas are flat, they are directional and need to be pointed at the transmitter area. I think you'd have to try it and see. I'd try it with the big 8 bay antenna and some mount that will let you point the flat part toward the transmitter.
If it's close (some stations OK, some drop out), you could fashion a box for the amp and run both a coax and the 12V power for the amp in your conduit to overcome the cable loss. Of course you can try the amp out 1st and see if it helps (at a lot of bucks to buy the amp and "try" it).
In a sense with all this stuff, cable and satellite have "spoiled" us. We are used to environments where we just wire it up and it works. But with this off air stuff, there is some trial and error and none of the tries are free.
Pete
/ VHF Gain Antenna
That's your problem. The antenna is indoors and too small. Although it may be advertised for VHF, physically it's a UHF and probably functions at a loss rather than a gain on both VHF & UHF. Is this what you have now: RCA ANT1650 Flat Digital TV Antenna with Removable Amplifier (ANT1650)?
[/url]
That is the size but it does not have the amp box and it is white.
This is the size I'm looking for. http://www.antennadeals.com/HD2605.html
/ VHF Gain Antenna
I do not have a gabled roof, so I will have to have an exterior mount.
I think the The 8 bay CM4228 would be my best bet at this 50 mile distance (It is good for 45 miles VHF and the Winegard HD7694 is only rated for 30 miles VHF). It also looks like a flat antenna and maybe it could be mounted fat on the brick wall facing Austin if I don't need the height and I don't need to turn it.
/ VHF Gain Antenna #17
go to AntennaWeb.org, enter your address and it will tell you where all of the stations are located, what direction and what frequency they are on and the distance to your location.
/ VHF Gain Antenna
* red
vhf KTBC-DT 7.1 FOX AUSTIN, TX c 265ー 40.8 miles
Got it thanks.
/ VHF Gain Antenna
Thanks again to TBN for the guided antenna research. I chose the Winegard antenna.
Winegard Direct.com - Winegard HD 7698P High Definition VHF/UHF HD769 Series TV Antenna (HD7698P) | Winegard [HD7698P] HD769 Series 769 7-69 high band hi band hi-band HD7698 HD 7698P HD7698P HD-7698 HD-7698P
I now get VHF Fox7 and the other nine UHF Austin channels on HD at full signal strength!
I got the full signal when I first hooked up the antenna on the porch so a high elevation was not necessary. I mounted it at ten feet. I did not have a gable facing Austin (metal roof) so I had to mount it on a pole on the west side of the house.
The antenna was larger than I wanted at 14 ft. but at least I didn't waste any time or money going through small antennas like my neighbor did.
What surprised me the most was the variance in prices, and shipping charges.
Sears shipping charge was $175 ($304+tax) and Ritz Camera had no shipping charge for the same antenna for the same price $129.
2716SFL (A61567)
2716SFL (A61567)
2017 Maserati Ghibli Sedan (A61574)
2017 Maserati...
FORREST CITY 2R BED SHAPER & CONDITIONER (A63291)
FORREST CITY 2R...
2009 Ford Escape Hybrid SUV (A61574)
2009 Ford Escape...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
JMR Tree Boom Skid Steer Attachment (A61572)
JMR Tree Boom Skid...
