Oil & Fuel tighten the filter
/ tighten the filter #1
heehaw
russellville, arkansas
Kubota M4900, B7510 and RTV
i learned a little lesson: i have changed oil in all of my equipment for about 40 years, never had this problem before, but i changed the oil in my B7510 about a year ago: use it mostly to mow with, an just put it in the barn a couple weeks ago, after mowing a couple acres: went to get it out saturday morning: started it up an began backing...oil going everywhere!!
the oil filter was about to fall off...maybe my hand tight just isn't as tight as it use to be, so from now on, i WILL snug all filters with a wrench.
heehaw
/ tighten the filter #2
heehaw
Hand tight should be more than adequate. Just to be safe, I would pull the filter off and make sure you didn't leave the gasket on from the previous filter. This happends sometimes. With the old gasket in place, when the new filter is screwed on you have a "double gasket" and that does not work. The old gasket blows out. Usually happends right away though.
At least you discovered this before you lost too much oil and did bad things to your engine!
/ tighten the filter #3
Bummer about the oil.
Along those lines, I just did the 400 hr. maintenance on my L3240. The manual says that the HST filter should be hand tightened until contact and then wrenched on 1 complete turn after that.
Thats quite a bit more than hand tight which only seemed to go about 1/4 past contact.
I'm surprised that it needs to be that tight but I guess there's a lot of pressure there.
/ tighten the filter #5
You may just want to double check to make sure something didn't get tweaked. Had a guy working on one of our large marine engines (1800hp Cummins) and he was cleaning behind the engine in a tight space. Long story short, he had 'pushed' against one of the oil filters (they are quite large by the way) with his foot while reaching for a dropped tool. He tweaked it just enough so that nobody noticed until the filters kept dropping off when the engine was running. Couldn't figure it out for the longest time why the filter would eventually drop off. Thankfully our engineer always caught it immediately and shut things down. Finally, upon very close examination, we could tell that when screwed up all the way to the housing, the filter wasn't flush all around its mating surface. The threaded rod that the filter screwed onto was tweaked. I guess this was all it needed to vibrate itself off over time. New filter housing solved the problem. I tell you it was the weirdest thing. Couldn't figure out how a filter could bounce around on a truck all day, but would spin off our engine!
Is it possible that your filter could somehow have taken a hit? Just a thought.
the filters are $13 at the local kubota dealer, but thats still cheap compared to messin up an engine....i will be changing oil an filter on that tractor before i use it again....just to make sure...plus i am going back to all the rest of the equipment i have an snug the filters up with a wrench..
heehaw
/ tighten the filter #8
just a quick laugh about the filter wrenches - I "spoiled" myself with one when I bought some oil and filter for my wife's Honda. This wrench was the type to fit the filter exactly. Previously, I have only had the type with a flexible metal ring that tightens around the filter as you turn it.
I had to laugh though when all I did was move my problem of not being able to fit the wrench around the filter to not being able to get the wrench off the filter. Had to get a hammer to get it off!:laughing: Good use of money:mad:
/ tighten the filter #9
I had a new filter with the threaded hole bored crooked with respect to the axis of the filter. I screwed it on tight, started the engine, and oil shot out because the gasket wasn't mating tight on one side of the filter. Took it back and got a new filter. I guess bad products sneak off the production line every now and then.
/ tighten the filter #10
I once had an oil filter that I couldn't get started on the threaded pipe on the engine. A closer inspection revealed no threads on the filter. That one went back in a hurry!
/ tighten the filter #11
Once we got reman engine in the vette shop and the old filter was so tight on it, I twisted off the filter metal housing - not sure if they used air to get it on or what:confused:
years ago, i bought a 1965 chevy truck, 6cyl engine, an i ran into the same problem: ripped the whole filter off the motor, an finally took a chiesel an hammer to the edge of what was left an got it off: luckily with the 6cyl motor, i had plenty of room to get to the filter mount.
heehaw
/ tighten the filter #13
Had my mechanic change the oil and filter in my 89 Nissan.
About a weak after getting the truck back the oil light came on .
Checked it an the tip of the dipstick just barely showed it had oil on it.
Called him and he came to my place to check it out.
He found the oil filter was leaking in spite of the fact that it wasn't leaking when he installed it.
When he removed the filter the gasket was all wadded up.
Evidently the gasket was defective but that didn't show up until about a weak of driving the pickup.
2 things I learned
1*Check oil level often after changing.
2* Park over a piece of cardboard for a while in search of new or unusual leaks,
/ tighten the filter #14
It seam weird that you were able to drive the tractor with no problems then the next time you went to use it the filter was half off. Maybe it loosened up the last time you used it but you would think you would have noticed then. It's not like just sitting the filter would work itself half off. Are you sure nobody messed with it?
I always put oil on the gasket before putting the filter on and use a wench to give it a little extra. BTW I hate Fram filters that have that black stuff on the bottom. It makes those "filter sockets" not fit worth a **** and near impossible to get off the filter. Maybe I'm a little to protective of the engine but if you loose your filter you best be very quick or you will loose your engine as well.
/ tighten the filter #15
Fortunately one of my car filter wrenches also fits the Kubota filter perfectly. BTW, I have used a leather belt (the kind used to hold up your trousers) for filter removal in tight spaces...works well, but trashes the belt.
/ tighten the filter #16
had a car once that kept blowing out the oil filter seals: turned out it was a defective pressure relief valve in the oil pump. Fixed the pump and the problem with the filters leaking went away.
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
207272 (A52708)
207272 (A52708)
Headache Rack (A61166)
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2020 Forest River Surveyor Camper, VIN # 4X4TSVZ21LL037533 (A61165)
2020 Forest River...
