DIY Steering Knob
/ DIY Steering Knob #1
troutsqueezer
Pilot Hill, CA.
Kubota B21
Ok, it ain't much...but there's a cool factor - however small. :cool:
I could have splashed down 20 bucks plus shipping to buy one of these over the Internet but I'm cheap and they look so easy to make. Now, whether it works or not, I won't know until tomorrow when I come home from work and try it on.
Started with piece of aluminum rod and turned it to shape.
Parted it off.
Scrounged up parts from around the shed. Tried to keep the parts galvanized as much as I could. I put rubber grommets over the nuts so as not to scrape my hand accidentally. I lined the inside of the clamp with rubber to keep it from slipping around the steering wheel.
Fingers crossed.
I'll take another pic tomorrow after it's installed.
/ DIY Steering Knob #2
Parted it off.
Fingers crossed.
Wow! That's beautiful. I want one!
/ DIY Steering Knob #3
The storebought spinners are designed to fit over the wheel at the junction of one of the spokes. Mounting it to a spoke keeps it from slipping in both the x and y axis. Sorry to use those terms, but that's the best way I know to describe the two directions it can move. I suspect yours will be able to move some unless you can get it to grip the wheel very tightly. Still, a very nice piece of workmanship for next to nothing in parts and you won't have to worry about it rusting!
/ DIY Steering Knob
Thanks for the heads up. I didn't get a chance to try it on this evening but I'm already thinking of a way to modify it in case it does want to move.
I'm wondering where the best spot would be to mount it? I'm thinking 6 O'clock. Any reason another spot might be better?
Thanks for the compliments guys.
/ DIY Steering Knob #5
It is cool, greaat workmanship:thumbsup:
Now, you gotta know that I have 3 spinners and love them...yes, all on the same steering wheel. Turns out that my tractor and many others no longer have a direct connection to the front wheels, but are hydraulically connected. This means that the position of the wheel versus the tires moves around...no set location...thus spinner doesn't stay in one spot...thus, needed 3 of them to make sure there would be a spinner under my hand when I need it to be.
Your spinner location may vary:laughing:
Did you do all those drawings for the spinner?? That's a work of art itself!
/ DIY Steering Knob #6
Nice piece of work.
Thinking out loud here, if you have full hydraulic steering, i.e. no direct mechanical connection between the wheel and front axle, will the wheel be in the same location in relation the the front wheels everytime?....Mike
/ DIY Steering Knob #8
Nice piece of work.
Hydrostatic steereing is the term you guys are looking for...and yes, often the spinner would be in a different place.
/ DIY Steering Knob
Thanks again! The drawings are for one of the model engines I am building. You can see a version in the background of the second pic. That one is an internal combustion hit-and-miss. I didn't do the original drawings but I have modified them heavily.
Nice piece of work.
Well now...my tractor is new to me and I've not thought of that. It's a Kubota B21. Does that have hydrostatic steering? I'm at work so can't go and look. If it does, I guess the question is moot.
Being cheap would be using a door knob lol
Good point. I'm thinking though...those door knob types seem to be a thing of the past, at least around here. If I went to the flea market to find one, I bet they'd charge me a few bananas, you know...it's an "antique".
What lathe is that?
That's the Harbor Freight mini lathe, 7 x 10, made by Seig. Not a bad lathe for the price, as long as you do some modifications to it.
/ DIY Steering Knob #11
Does your knob have bearings? I made one a few years ago for a lawn tractor out of a door knob. It worked OK but since it didn't have bearings it turned hard and eventually wore out. Bearings may be overkill but even bushings would let it rotate smoothly.
I am in need of another knob so I am looking for some good ideas on making one.
Nice lathe work. :thumbsup::thumbsup: I have wanted a metal lathe for a while but don't have the money.
/ DIY Steering Knob #12
Looks good,
I have always put the spinner at 9 o'clock.
/ DIY Steering Knob #13
looknlearn,
You should be able to chuck a piece of plastic with a 3/8 in bolt in a drill press, and turn down the piece to your satisfaction, and polish it.
/ DIY Steering Knob
No bearings. Thought about it but I'd have to buy the sealed kind to keep them from rusting. I think it'll turn OK, it feels good in my hand (no jokes) but if it doesn't pan out on the steering wheel itself, or wears badly after a time, I do have some Delrin rod which I can make a bushing from. Maybe I should do that anyway....hmmm....
9 O'clock sounds good. I guess when I'm put-puttin down the road it's easier to rest my hand on the bottom of the wheel.
/ DIY Steering Knob #15
The only bad thing about spinners is when your tire hits a stump and the steering wheel spins around and whacks you good. It jerked the spinner out of my hand and spun around before I could recoil. I couldn't feel my hand for 30 min.
/ DIY Steering Knob #16
Thats an idea!
I may try that or go with one from tractor supply. I like the feel of the bought ones. I'll investigate it and see what I can find.
Ideas are always welcome.
/ DIY Steering Knob #18
That's what I heard, I have an old Logan but this would be neat just for the detailed work and threads.
2014 CATERPILLAR 259D SKID STEER (A65053)
2014 CATERPILLAR...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
2018 Ver-Mac S/A Solar Towable Speed Trailer (A64194)
2018 Ver-Mac S/A...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
2011 Kenworth T300 S/A 17ft. Cab and Chassis Truck (A64194)
2011 Kenworth T300...
