splitter trouble
/ splitter trouble #1
rbushmaster
Member
hey guys,
i was splitting wood today when all the sudden i couldnt generate more that 300 psi on my gauge, log lift is working fine,it seems as if the relief is bypassing,
could it have blown a cylinder seal ? and is there a way to check /test?
thanks
/ splitter trouble
Member valve rd 5000
took prv out apears to be a sealed cartridge, i cant figure out how it comes apart, so i hose it out with brakeleen
put it back together and its the same, cylinder stops at 400 psi, if i increase engine rpm to full throttle i can get 1000 psi
when the cylinder hits its 400 psi resistance and wont travel any further i hear a shhhhhhhhh noise
/ splitter trouble #4
Do you have a two spool valve, or two different valves? Please show some good pictures. Did you change any hoses?
What pressure were you getting before this happened?
I believe that relief cartridge is adjustable.
/ splitter trouble
hi jj,
2 spool valve
power beyond
no changes were made was getting 2250 psi before relief took over then it went to not splitting and only getting 400 psi
/ splitter trouble #6
Is the fluid foamy?
Any easy way to check the cylinder seal is to extend the cylinder all the way, then remove the hose from the rod-end, now operate the lever to try to extend it further, if fluid squirts out of the open port, then the seals are bypassing.
/ splitter trouble
fluid was fine,
ill try that with the cylinder
extend all the way out
remove the line on front of cylinder that would make the cylinder return to see if fluid is bypassing seals correct?
extra info
new 22 gpm barnes 2 stage
new prince rd 5000 2 spool valve
used 4.5"x2"x36" cylinder
18 hp briggs
have split 4 cords with engine just above idle
would stall the cylinder at 2250 psi with gnarly knotted peices relief would open and not even effect engine rpm
/ splitter trouble #8
Which one of these part numbers do you have for the RD5000
That pump only needs a 12 HP engine
20-2012* 522ACAA5A4B1 1 single, 1 double-acting spool, spring-ctr'd*
20-2022 522CCAA5A4B1 2 spool, both double-acting, spring-centered
20-2022-75 523CCAA5A4B1 2 spool, both DA, spring-ctr, all ports 3/4"
20-2042 522GCGA5A4B1 1 DA w/ float, 1 DA spring ctr'd
20-2021-SAE 525MMEE5A4B1 Autocycle valve (w/ conv port)
20-2022-J 522CCAA5A4B6 Joystick, 2 spool DA, spring ctr'd
20-2042-J 522GCGA5A4B6 Joystick, 1 DA w/ float, 1 DA spr ctr'd
/ splitter trouble
the 18 hp was free..... runs great but sure does burn up the fuel
the valve is
522ccea5a4b1
surplus center #9-7414
prince 25gpm 2 spool log splitter/lifter valve
3/4 ports
1/2" work ports
with power beyond sleeve installed
/ splitter trouble #10
fluid was fine,
Yes.
Everything else is new...focus your attention on that used cylinder...
/ splitter trouble #11
Is the pump staying in low pressure mode or does the pump shift to high pressure when things get tuff. Do you have another cyl to just attach your hoses and check the pressure on the pump.
/ splitter trouble
thanks guys
its the cylinder seals
with cylinder fully extended and cyl. return hose off i get full flow out of the disconected port on the cylinder
/ splitter trouble
tore it aprt and the seals are pretty ugly, one side looks as if there was a bomb under them
2015 Mack CXU613 Tri-Axle Day Cab Truck Tractor (A64194)
2015 Mack CXU613...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2022 EZ-GO ELITE...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
Blender Trailer (A64194)
Blender Trailer...
2005 IC Corporation PB105 School Bus (A64194)
2005 IC...
