Compression test gone wrong
/ Compression test gone wrong #1
kenneyk
1510 ford 1983
hello to all I Have a 1983 1510 ford
I was going to test the compression of my tractor with the injector out
and I Blew out the small metal flat ring with a hole in it, and I can't find it
does anybody know where I might find another one, or whats it called
Thanks
/ Compression test gone wrong #2
It's a compression seal washer. They're usually made of copper or aluminum, but some are mild steel.
Your local dealer should be able to get one, or any diesel fuel injection shop will be able to get you one if they have a sample to go by.
Sean
I Have a copper washer and the other piece that got lost was a Bowl looking with a hole in it, thats reset Is this what your talking about?
/ Compression test gone wrong #4
I'm having a hard time picturing the missing piece. Sometimes there's a domed washer as part of the hold down arrangement, but that would be external to the injector hole, it fits over the stud that holds the injector clamp in place.
Sean
/ Compression test gone wrong #5
Sean
It is called a Yoke.
/ Compression test gone wrong #6
Thanks
I have used a Pluming supply for the copper washer.
/ Compression test gone wrong #7
G'day i think what you are refering to is like a ball cut in half with a hole in the middle for the inj nozzle to go through and it sits in the inj tube below the copper washer, these are usually there to hold the injector tube in the head i think the only place to get on would be genuine.
Jon
/ Compression test gone wrong #8
Yep, we're going to need pictures.
Sean
2017 BOBCAT S650 SKID STEER (A63569)
2017 BOBCAT S650...
2006 Toyota Sierra CE Van (A61574)
2006 Toyota Sierra...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
2025 DE14 Tophat Dump Trailer (A64047)
2025 DE14 Tophat...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
