Exhaust Muffler
/ Exhaust Muffler #2
IMO it looks to be for a smaller tractor than what you have. This pic. should be the same as what you should have. Did you get my PM.? You good with That ;).
Carey
/ Exhaust Muffler
I wrote you back Carey...Thanks...I agree it is for a different tractor. The cheap price got me excited. It doesn't look to have a mounting flange on it either. DUH...
/ Exhaust Muffler
Carey
Man that looks nice Carey. Thats your rig?
/ Exhaust Muffler #5
Just finished cleaning and touching up the grills/white with the spray touchup paint. I went out of commission for awhile and had it since I bought the parts it needed. I touched the grn.up awhile back. Like I suggested before get the maintenance and tractor working properly then work on cleaning it up your give it alittle more TLC. :)
Carey
/ Exhaust Muffler #6
I had thought of re-routing the exhaust to under the tractor and have the pipe exit out from the rear of the tractor as would a car would be, although was told that the more length and bends in the pipe would cause restriction and back compression, so I opt out on that idea:cool: If I wer you I would have preferred if given a choice to had left the pipe as it were on yours, this would have kept the exhaust and sound further away from the driver,.... But now that I have a FEL I have no other options other than to leave it as it is in the upright ...;) Carey: your 2000 is looking good, you must be doing better these days :thumbsup:.. My most recent tractor time has been using it to clear a pathway through our woods for the Halloween hayride event, then will use the tractor to pull a trailer full of Ghouls,:thumbsup: I guess this would be another good reason not to have the exhaust coming out the back :D
wpuldn't want to Gas the ghouls :laughing:
/ Exhaust Muffler #7
Some with FEL's have enough clearence to turn it foward 90 degrees to point down. Winston has pics he has posted on here before. But he has a different tractor and loader and did you not build yours? so that also may be a difference aftermarket ones may leave the space for the turn?
/ Exhaust Muffler #8
Here it is, I mow under a lot of trees and need a low profile. Has worked good for me. This is a 2002d
/ Exhaust Muffler #9
Deep, I had been thinking the same thing. If I turn the muffler straight down, and depending on where I cut the pipe I believe I could use a 45 instead of a 90. There would naturally be a few slight sweeping bends to get to the back. Do you remember who told you this? If restriction is a problem maybe a 2" pipe may solve the problem. Maybe one of our dealers will chime in .
/ Exhaust Muffler #10
ninefinger, I wouldn't think having a 45* bend would cause any restriction on a downward flow, I had been transporting my tractor one day when I stopped in to talk to an old friend who owns a muffler shop, and I brought up the reconfiguring of my tractors exhaust to the rear is when he advised of the possible holding back compression ( exhaust ) when having to bends around the QC to my loader and many other things being a routing problem,
he would have had to make 7-8 bends and use about 6 ft of 1 3/4 pipe and then find a place to put the muffler,
said something about scavenging diesel exhaust would lay in the pipe, the tractors 2 cyl. diesel engine wouldn't blow it all out the way he would have to rout the pipe,and would not be on a continuous downward flow,
he could however simply dump it down about midway of the tractor but he also said I would hear it even more when sound rebounds off the ground, Kinda like having turndowns on your cars exhaust right at the rear axle, I do know how that is:confused2: cant hear myself think:cool:
/ Exhaust Muffler #11
Both of the tractors that I use regularly has Vertical exhausts and doesn't bother me at all. The ym2000 and the JD5103. On my 8n Funk the exhaust is horizontal to the rear like a car and that is the only one the exhaust seems to get to me the most. Esp. if I'm moveing slow or sitting still. The 5103 that has a FEL. is the only one IMO. that has the power to even have a FEL. With the vertical stack if i'm in under tree's etc. easy Fix Just reach up and remove the Exhaust pipe and slip it back on when you clear it. :rolleyes:
Carey
/ Exhaust Muffler #12
Carey
your 8n also is gas and prolly needs that much bend pipe to get the scavenging effect of the backpressure on that 6 or 8 cyl funk.
/ Exhaust Muffler #13
Is scavenging (Using the inertia of the exhaust gasses to pull clean air into the cylinder) relevant on these antiques? I doubt it. Seems to me the original design specified a pipe large enough to prevent back pressure at maximum rpm so re-routing the exhaust should have no effect short of that maximum rpm.
2018 Manitou MLT634 7,000lb 4x4 Rough Terrain Telehandler (A66734)
2018 Manitou...
2007 JLG G6-42A 6,600lb 4x4 Rough Terrain Telehandler (A66734)
2007 JLG G6-42A...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
CASE 721E WHEEL LOADER (A67714)
CASE 721E WHEEL...
2006 JOHN DEERE 310G BACKHOE (A65053)
2006 JOHN DEERE...
Set of 4 Unused 10-16.5N.H.S. ForeRunner Skid Steer Tires (A66734)
Set of 4 Unused...
