Hydraulic drive question
/ Hydraulic drive question #1
handirifle
Central Coast of CA
Massey Ferguson 1010
Here I go thinking again, I usually end up either embarrassed or confused, but here goes.
Have been toying off and on, about building some sort of vehicle to cruise around on, while on the property. My land isn't big or steep, but I do have a few uses for it. Also being thrifty (spelled cheap) I thought I could build one, if and when the pieces showed up real cheap.
It would be a sort of golf cart UTV type of rig, but before anyone suggests, I am not a fan of golf carts themselves, gas or electric. In my opinion, when I'm about to run out of power, it faster and easier to gas up than to charge up. The gas golf carts that start when you hit the gas, I do not like either. Yea I know, I'm picky, but hey, it's my idea.
What came to my mind, last night, and the reason it's posted here, if wondering how efficient a hydraulic drive would be? I could use a 15-20hp engine, to drive a hydraulic pump, and use that to drive the vehicle. Reverse and forward ought to be a simple affair, but what I do not know is what kind of speed I could expect. I suspect the thing would be easily under 1,000lbs and a top speed of 10-15 would be plenty, I just do not want a crawler.
Thoughts?
/ Hydraulic drive question #2
You might be able to use the hyd transmission on the 20 to 25 HP lawn mowers/tractors. If you increase the tire diameter, it will run faster, but will decrease the torque. If you try to make it up from scratch, you will have to look at engine,tires, load, torque, speed, hyd pump,motor, valve, hoses, etc.
/ Hydraulic drive question #3
I agree with JJ, you can use a transaxle from a hydro or gear riding
mower. If you look around, you can often find a free non-op mower
sitting around in your area. Whether or not you go with hyd drive, the
mower transaxles usually have a differential, reverse, and integrated
brake. Surplus Cntr has a bunch of them new, too. This one is only
$79, plus shipping:
https://www.surpluscenter.com/item.asp?item=13-1471&catname=powerTrans
BTW, I recently sold my 12.5hp JD gear riding mower....it was scary-
fast in 5th gear.
/ Hydraulic drive question #4
Speed range is a problem with any hydrostatic drive, HSD. HSD loses a lot of efficiency at higher speed, due to increased mechanical friction at high flow on the variable HS pump. To increase speed range you will need a variable HS motor, but the same problem will still be there...... inefficiency....
You will "kill" your engine at 15mph, if you get into any kind of resistance...
I would say that a v-belt drive like an ATV or snowmobile is the best alternativ....home built HSD is an "expensive hobby" at the most....
2c
:cool:
/ Hydraulic drive question #5
2c
:cool:
X 2......Unless you have another HST Donor Vehicle to scavenge the components the build would not be cost effective to fabricate by the seat of your pants......If you did have a donor vehicle of sorts you could set up the hyd drive motor with chain drive so if the speed/torque ratio's aren't good then changing sprockets is cheaper than changing displacements on components......:2cents:
/ Hydraulic drive question #6
With two of those transaxles and a 15hp (verticle shaft) you could build a half track? One axle probably won't support much weight. I am building a hydraulic drive with tracks. I should know in a week or two if it will move. Spending about $4500 bucks!
/ Hydraulic drive question #7
Hope you are having a lot of fun!!:laughing:
WOW that is WAY more than I was hoping this idea would run. As usual there's a million things I didn't consider or was aware of. I had thought before of the mower idea, so maybe I'll go back down that road.
Thanks guys for all the good replies.
/ Hydraulic drive question #9
I often thought of the idea as well as many others. I know a little about hydraulics as I studied in school a couple courses. I thought about making a atv similar to david devunos hydraulic dumper. The overall vehicle wouldnt be a problem, but I'm wondering what they have out there now for devices used for drive system. I would need a drive system with enough power to haul maybe 4 200lb men, with tracks in soft ground, top speed on a hard surface of maybe 20 mph. I currently use and have many J5 bombardier tractors, which has the ruggedness and power needed for the work, but the problem is its slow on rocky terrain. This is where the 4 wheel atv excells. But when we get into the peat moss and bog land, with creeks and deep holes, the rubber tires dont cut it like tracks do. So i thought about making a tracked machine to carry 4 men, for nothing more then to carry personal, with a soft suspension for the rocky trails but with the low ground pressure for the bog lands. when We need the heavy work, I can use the J5. But the Hybred tracked machine would go as fast as an atv on the large bouldered trails and as fast or better on the soft spongy bog land, but capable of carrying 4 men. My probably is, I know how tough a drive system needs to be . Transaxles I have little knowledge, but they look too slight. Whats out there that I can use that would take the heavy drive force of 800 or 1000 lbs in rough terrain over boulders. I would be afraid of some drive motors wouldnt be able to handle the lateral loads. Need some advice.
/ Hydraulic drive question #10
If you check out "My Tractor Forum" you may find the type of set up you are talking about. I have seen in the past couple of years different track build set ups that do not use hydrostatic drives.
/ Hydraulic drive question #11
Yes, HSTs that use variable displacement pumps are less efficient than
any gear or belt drive. Because of the narrow speed range, they
are supplemented with speed/torque multiplier gear boxes. That's what
we have in our HST tractors.
Many of these free or cheap riding mower final drives have speed
multiplier gearboxes, too. Using a hyd pump/motor to drive the input
shaft (instead of the mower's belt) of these mower drives is a doable project.
/ Hydraulic drive question #12
Agree with you dfkrug.....but where do you find a mower drive for a 4000lbs application?
Hydraulics is a lot of fun, but one have to be realistic about "cost", time and money to not say ingenuity, experience and a very good shop.
A 4 seat HST ATV, on a rocky trail, will for sure travel with three empty seats....passengers will walk faster and safer than riding.....
You're not talking aout MY idea are you? Not at 4,000lbs. I figure mine will be in the 1,000lb or less category.
/ Hydraulic drive question #14
No I meant the VroomVroom's comment... BUT i still think it is a waste of money, time and fuel energy...compared to a straight mechanical belt variator solution....
/ Hydraulic drive question #15
Here is a hyd driven machine built by Power-Trac, with 6 wheels with 6 hyd motors, and a 25 HP engine, and 2 VSP transmissions. Scroll down to the bottom half of the page for all the particulars and a video. The cost is rather high, but with some scrounging, and a used engine, might bring the cost way down. 16 MPH. It floats, ;and climbs a 60 degree slope with a 1200 lbs load. What else do you need?
UV Class
/ Hydraulic drive question #16
You would need straight rubber tracks for use on rocks. This is why I am building my unit, not much out there that will do what I need. I need something that can dump, plow, carry two and be easy on the back. Even the Argo's with track kits are pretty bumpy. Commercial Carriers have no suspension. For me I don't need speed and needed hydraulics for the plow and dump so going all the way. The cost of build is high, 3 separate spool valves, three hydraulic cylinders, big v-twin motor, oil tank,oil cooler, strainer, filter, two hydraulic motors, three relief valves, one flow divider, one flow controller and a ton of hoses and fittings. Tracks alone had 70 feet of belting and 120 feet of steel and about 480 nuts bolts and washers etc.
I won't squawk much next time I see the cost of a set of tracks. If I had to start again I would look at a half-track. Best possible traction with a much simpler design.
Hitch-A-Track
/ Hydraulic drive question #17
Indeed, none of the mower drives are good for a 4000# machine.
A hyd-drive machine completely from scratch? I would consider buying
plans for something like the CADPlans CADTrack articulated loader. But
that's not tracked, as the OP wants.
However, scrounging for an engine, and maybe a set of used mini-ex or
skidsteer tracks, then buying the hyd drive components surplus.....
/ Hydraulic drive question #18
Well, Like David devouno's dumper, there is nothing out there which would work like I want it to. It doesnt have to be hydraulic at all. Im not sure how a rear end out of a truck would work. the problem with those argos and the like is they are solid, they have no suspension, they tried them here and they dont cut it. The are low to the ground, plastic in most cases and the because of the sold nature they break more axles, blow more tires and ruin more axle bearings then any other atv I know. they wouldnt be much faster the the J5 in fact, I wouldnt say they would be any fast on the rocks because of the solid nature. The J5 works well, but slow on the rocks...so I wanted to build something that had a really soft suspension, but with low ground pressure. They need to make an argo of sorts with bigger wheels, and independent suspensions. The rhinos and such can probaly seat 3 or so, but would like at least 4 and they are wider, longer, same engines, and only the same diameter tires as the 4 wheelers....so they will hang up more. I will post a picture or two in the near future when I get the chance for you guys to take a look. Do you think a rear end truck axle would work on such a machine?
For your application, I'd look into an old Jeep, set up for off road only. No need to make it go fast, and you could easily gear it down with an axle swap to say 5:13 ratio or lower. With those gears and in low range there'd be very few places it would not go.
My '01 Wrangler had 4:10's and I took it into places that were almost scarry to me. For your app, I would raise it ONLY if necessary to clear your tires. It already comes higher than all the ATV's out there anyway.
Look for a TJ model, as that's when they went to coil springs in the front, much softer ride, on and off road.
/ Hydraulic drive question #20
I'd be looking at one of thoses J5's. Put it on a diet and make up some rubber inserts for the tracks and you would be good on the rocks. You could make a 4 seat cab (I know we had three of us in one. make the cab extend over the tracks.
