Concrete drying time
/ Concrete drying time #1
RobA
Chester County, SE PA
Kubota L5030 HST
I had concrete ramps poured for my barn. I believe they are 5" thick. How long before I can drive something like an ATV over them? How about a tractor?
/ Concrete drying time #2
I assume these ramps are poured on the ground and not structural concrete "planks" or "beams".
Then ATV probably within a couple days and another one at most for the tractor.
/ Concrete drying time #5
Did you put in any rebar? If so 7 days is plenty cuz if they crack they will not separate so no big deal. Concrete tends to crack eventually outside anyway, but if w.o rebar I would wait as long as you can stand it [up to a month] to give it a chance to reach a good proportion of its ultimate strength. I have broken up parts of a concrete pouring over time as needed. There is no comparison between 1wk and 1mo concrete.
larry
/ Concrete drying time #6
The atv can drive over in 2-3 days. With the tractor, I would wait a week. Both estimates are on the conservative side and your pours are relatively thick at 5".
/ Concrete drying time #7
Concrete does not dry, it cures. Setting is a chemical reaction that requires water to proceed. If you let it dry out, the curing will stop at whatever point it has reached.
Curing rate depends on temperature, but it will normally reach 50% of final strength in a week, and 90% of final strength in 21 days. Moist curing for 28 days will double the final strength of concrete vs. leaving it unprotected in air.
/ Concrete drying time #8
Concrete does not dry, it cures. [Moist curing for 28 days will double the final strength of concrete vs. leaving it unprotected in air.]
Good. .. forgot to mention that.
/ Concrete drying time #10
what is your source of this information...?
the compressive strength of concrete is relative to the water/cement (portland) ratio...keeping it wet will enhance the curing but it will not likely "double the strength"...
/ Concrete drying time #11
/ Concrete drying time #13
Being in the school construction business, I supervise pours totaling 3-4,000 CY per year, about half structural concrete and half flatwork. Being a state agency, we are required to make cylinders for testing from every pour. A minimum of 4 cylinders to be broken one at 7 days, two at 28 days (the design parameter) and a hold for 56 days if the 28's don't make strength. We make cylinders from the first truck and additional sets for every 50 CY.
Since we are in earthquake country, and since the safety of kids is our highest priority, our typical structural concrete is 4,000 PSI and out flatwork is 3,000. We use a .45 water cement ratio for corrosion resistance and usually a 3" to 4" slump. Remember, schools have to remain structurally sound for more than 50 years.
We do a 7 day water cure either by full flooding or mats.
The bottom line is that 90% of all breaks will reach 80% or greater at 7 days and 125% at 28 days. It is not unusual to see breaks up to 6,000 PSi at 28 days.
Now this is not your usual run of the mill concrete and we are required to have a plant inspector at every batching, but it is typical for most concrete.
/ Concrete drying time #14
Pls elaborate on this statement. Exactly what are you saying.?
larry
/ Concrete drying time #15
We just had a floor poured at work, It was poured 6:30 am on a Saturday and we were driving forklifts on it at 5:00 am the following Monday with no problems so far. They said it was a seven bag mix, whatever that is. I think a regular mix is called a 5 bag mix. I think in 2 days a four wheeler would not have any effect unless you had studded tires it may score it more easily.
/ Concrete drying time #18
larry
Concrete test cylinders are typically 6" diameter by about 15" high. They are prepare by a certified inspector according to ASTM specifications. At 7 days they are placed in a hydraulic press and crushed. The pressure to crush them determined the compressive strength of the concrete.
Ninety percent of the 7 day breaks will reach 80% of the design strength. i.e. 4,000 PSI design mix will result in a 3,200 PSI strength at 7 days.
A typical cylinder will take 40 to 50 tons of force to break it.
/ Concrete drying time #19
The "breaks" he's refering to are test samples that are taken at the jobsite, cured, and crushed at specific cure dates in a lab. MikeD74T
Thanks!
:thumbsup:
/ Concrete drying time #20
Yeah, it really depends on what kind of concrete you had poured. I was driving on mine after a couple days, but it was "High Early" due to the fact I couldn't wait 14 days for it to cure. My concrete guy said it's not so much the driving as it is the turning of the tires that puts the most stress on it.
Yours didn't give you any guidelines?
Gehl RS5-19 (A62177)
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A63688)
Magnolia Trailer...
2005 John Deere 6x5 Rotary Mower Tractor Attachment (A61572)
2005 John Deere...
2024 John Deere 6R 145 Tractor (A63111)
2024 John Deere 6R...
2012 Ford E-350 Passenger Van (A61573)
2012 Ford E-350...
2002 WACKER RD25 ROLLER (A59912)
2002 WACKER RD25...
