Posthole Digger PTO-driven post hole auger suggestions
/ PTO-driven post hole auger suggestions #1
jedjoe
Warren, Connecticut
new holland TC 35A 2004
Gentlemen,
We've started an implement cooperative in our neighborhood, as three of us all have compact tractors in the 30-35 horsepower range with category 1 three point hitches. Our next collective purchase is a PTO driven post hole digger. None of us are going to beat the heck out of this tool, but we do live in New England with it's rocky soils.
I'd be interested in hearing what brands and models you guys might suggest. Pros and cons, and approximate fair retail price would also help.
Thanks in advance,
Jed
/ PTO-driven post hole auger suggestions #2
The Leinbach L7200 is a good one for the price. I've had one for about 12 years now and it works just fine, although I did notice the other day there is a little bit of a leak on the front seal where the input shaft is. Since I bought mine a dozen years ago, I paid $365 for it, which included a 9" auger. I see that Everything Attachments has same one for $580 now!! I guess I got a deal huh? :)
/ PTO-driven post hole auger suggestions #3
I recently bought the Lienbach L7300 and have drilled maybe 100 holes so far. I am quite happy with it.
/ PTO-driven post hole auger suggestions #4
I bought a Work Saver 15 years ago and I have planted 1500 trees with it balls with it. I had it out yesterday relocating my mailbox.
Craig Clayton
/ PTO-driven post hole auger suggestions #5
I like my L7300 but I think the tip of the auger is way too small. If working on a slight angle, it doesn't bite in that good...
I took the suggestion to get a cheap 36" pipe wrench... sure enough, the PHD hit a root or a rock and screwed itself into the ground. I don't let the auger take that much of a bite before raising it and clearing the hole, now.
/ PTO-driven post hole auger suggestions #6
I agree, the Leinbach are probably the best value.
Not sure I would want to go into a collective purchase of a PhD with anyone though.
Augers get stuck, flights get bent, etc. friendships could get fractured.
I have learned to slow feed these things; no pushing the 3ph position lever all the way forward and waiting for the auger to run to the bottom of the hole (-:
I would probably buy it outright and drill holes for the other guys, always and only with my tractor - well, depending how far away they are (-:
They could make a fair contribution for whatever time I spend at their places, or return favors with different implements.
/ PTO-driven post hole auger suggestions #7
I have a Bush Hog Model 2102. The augers have "Bear Claw" staggered replaceable auger teeth that bite when they hit the ground so the auger doesn't "walk" when starting a hole. It also has the optional Bush Hog parking stand. I can back up to the post hole digger, insert three pins, lift it and go. I think it was around $1,300 for the digger and stand. It's an easy one man auger to mount and use.
I've looked at BH 2102. I think I could handle it on my NH 35, but is it too much digger for a smaller TC 30?
If it was any ol' neighbors, I'd agree that it would not be smart to share something like an auger (or a rotary cutter, either). But these guys are solid, and we are all sharing risks pretty well by each contributing 1/3 to all new purchases, and each putting in something substantial of our own attachments. Truthfully, I'm generally the heaviest user of all the equipment, so I kinda getting the best part of the deal!
I can't really see the difference between the standard 7200 (not the JR) and the 7300. How do they differ?
/ PTO-driven post hole auger suggestions #11
I think the 7300 is a little more stout (look at top tabs) but doesn't come with the metal pole to position (tilt/lean) the auger (look bottom right). I like the "guide" pole but it's bent several ways, I would go with the 7300.
/ PTO-driven post hole auger suggestions #12
the 7200 has the guide rod and a lighter casting of the gearbox. The 7300 has no guide rod and a heavier casting.
/ PTO-driven post hole auger suggestions #13
For what it's worth....I wore out a cheap post holer (generic brand x) and just recently purchased a Woods 65...it's built like a tank, heavy duty transmission and can take any auger size you need. Price is not as cheap as the ones previously mentioned but I figure this one will last me a very long time.
With the recession/depression in full swing...sharing costs is a great idea if you have trustworthy neighbors. That's how this country was founded. Sounds like you've all sat down and hammered out the details...congrats.
/ PTO-driven post hole auger suggestions #14
My 7200 came with the guide rod as well. Nothing more than a 6ft piece of black iron pipe though.
/ PTO-driven post hole auger suggestions #15
Heres two I own.Red one is a International(World Ag Corp) 12" auger.
Yellow one is a Speeco(6" auger).
Have to agree Leinbachs are good especially 8000/9000 mdls(thats where they start getting pricey)IMHO.Of course Bushhog,Woods make good stuff but seems to me lots of PHD's use Comer gear boxes.Not that there bad.Which I could be wrong but might be made in China.Also its no secret Danuser considered one of the best.I believe all Danuser components made in good old USA or at least they use to be.
Boone
/ PTO-driven post hole auger suggestions #16
If you've got an Agri-Supply where you can get to it they have a house brand which goes for about $500 IN STORE w/ auger.
We had a thread on this forum about it.
We don't have Agri-Supply but we do have Tractor Supply. Does anyone have any opinions about the King Kutter brand for a PHD? I would guess most opinions to be negative, but curious anyway.
sounds like the guide rod on the 7200 is a mixed blessing. I generally like to see my money spent on greater durability. Is the 7300 too big for a TC 30 (the smallest of the three tractors in our little cooperative)?? I've heard that sometimes the 7300 and the standard 7200 are too "tall" for a shorter tractor frame (which is why they seem to make the 7200JR).
Nebraska, can I ask what you paid for your Woods 65? And given the three tractor's horsepowers (30, 32, and 35), do you think the 65 is too much machine (say, vs. the 35)?
Danuser.....looks great, but $$$!!! Ouch!
