DPOCV supplier
/ DPOCV supplier #1
picker77
Gold Member
Central Oklahoma
JD 3032E, dual remotes, TnT, tooth bar, grapple
Does anyone happen to know the US equivalent of this UK supplier of DPOCV's? I'm wearing Google out trying to find these in the same small form factor. Lots of the giant versions available in the US, but haven't located the small ones yet.
Flowfit DOUBLE PILOT OPERATED CHECK VALVES
I've found dozens of suppliers in Turkey, India, Serbia, China, etc. Surely there has to be a stocking distributor somewhere in the USA.
/ DPOCV supplier #2
Check, Lock, Needle and Flow Control Valves 280-360 Detailed Information
whole page link
Hydraulic Cylinder Components, Products
/ DPOCV supplier #3
Sun Hydraulics in Sarasota Florida, HydraForce in Lincolnshire Il, Delta Power Co., Rockford IL. Parker Hannifin, Eaton. All of these companies make DPOCV's in various sizes and flow rates.
You will have to find a distributor for them in your area though.
Roy
/ DPOCV supplier
I appreciate you gentlemen trying to help, but as best I can tell none of those outfits, and none of the places I've looked at for the past week) have the small form factor valve I'm looking for. The valve I want has a body that's only about 2-1/2" long, 1-1/2" tall, and 1-1/4" thick. It's plumbed to a cylinder as in the photo, and is most commonly used for hydraulic top and side link applications. All those mentioned companies do make functionally similar valves, but their physical configurations don't allow this type of compact installation.
As I said before, these are common overseas, and I can get one from an outfit in the UK via Ebay (see item #310249502175) for $72 shipped (the shipping costs more than the valve, LOL!). I was just thinking I might find a stocking distributor in the good 'ol USA, but no luck. It goes against my grain to have stuff shipped from overseas, but this time it's looking like that's the way to go.
/ DPOCV supplier #5
You could perhaps contact the distributor of the cyl with the DPOCV and ask questions. like would you sell me just the DPOC, or where can I order one?
At the bottom of the page for CCM, they will sell any part of the TNT system.
http://www.ccmachinery.com/TNT.htm
/ DPOCV supplier #6
You won't find them...Use MadReferee (May he RIP) went through this years ago and could not find a US supplier.
Now, OTOH, user 3RRL (Rob) did buy some from CCM to put on his backhoe stabilizers. Read this starting at post #13: Backhoe Feet - TractorByNet.com
You can search either of their usernames and the term "DPOCV" for lots of reading.
/ DPOCV supplier
In case I decide I can't live with the approx 1" per hour leak-down on my new side link. I think it will be ok for box blading because I'm usually floating the box blade anyway, don't know yet if I'll want to put up with it when the brush hog is on there. Fortunately, the brush hog isn't used much since I got a big ZTR, I much prefer mowing with that.
I'm not sure why this is happening, but it is. SCV's are brand new and hard piped by the dealer, and shouldn't be leaking down like that IMO. Could be the new cylinder, I suppose. I used a 1.5"x6" for the HSL, and a 2"x11" for the HTL. Of course the top link has a DPOCV so it stays exactly where I put it.
It's a personal thing, I guess. I just hate droopy hydraulics. I thought it might be sucking air somewhere, but it's dry as a bone under pressure, and we're only talking a set of QC's, two 36" hoses, and a cylinder in the entire loop. Any kind of leak should be obvious.
P.S. Don't say it, MVR. I already know your opinion of DPOCV on side links. :laughing:
/ DPOCV supplier #11
the way tilt cyl is hooked up, gravity load pressurizing the rod side of piston, a DPOCV, wont be any full guarantee, preventing for drifting....only if gravity load hangs on the capped side....
This because if piston seal leaks, volume from rod side will fit into capped side, and the void will create vacuum....
An arrangement with DA Cylinder lifting with the capped side will be "drift free" with a DPOCV...
The way it is hooked up, you only need a single pilot CV for the rod side....
/ DPOCV supplier #12
You will always have more leakage in the CV (both spool and the work port PRV) than through a brand new piston seal
http://www.tractorbynet.com/forums/hydraulics/185353-dpocv-supplier-2.html#post2112671
/ DPOCV supplier
Hmmm.... yep, it's installed with the rod end down, mainly because that way I could do the clevis welding out on the rod end and didn't have to heat up the body of the cylinder.
So, I could get away with just a single in-line pilot operated check valve on the rod end? If so, the price goes way down and I know where I can get those.
AKKAMAAN:
"The way it is hooked up, you only need a single pilot CV for the rod side.... "
/ DPOCV supplier #14
AKKAMAAN:
Yes , because your problem is CV leakage, and if piston sel leaks a double wont do any good any way......well 15psi difference....the vacuum pressure on the capped side....
EDIT:Rod up or down does nopt matter, it is a matter of if the load resting on capped side or rod side pressure
/ DPOCV supplier #17
One item to consider is using DPOCV on a cylinder is thermal expansion. If you operate the tractor when cold and then let it sit in the sun you can trap and build some serious pressure in the cylinder.
Roy
/ DPOCV supplier
That one will do a trick for you, but not the desired trick....need to be pilot operated...like this one...
It is no biggie....you can use a double one too....by I thought a single could save a few bucks...
Ok, but on the Brand PC valve you pointed out (photo one) the pilot port would still have get cracking pressure from the other end of the cylinder, so it would have to be teed into the capped side of the cylinder. Right?
If so, then the single piloted check in photo two would do exactly the same thing, although because the pilot fluid's path is internal, the valve and its external plumbing would still look like the usual top link DPOCV setup (photos three and four). However, the valve itself should naturally be somewhat cheaper than the double version, and only one end of the cylinder would be locked. Correct?
Sorry for the high density of my brain cells on this subject. I've worked in electronics for 50 years, so I can do that in my sleep, but I've only played with hydraulics for a few weeks, and it's like first year algebra to me. :laughing:
/ DPOCV supplier #19
That is correct, but the pilot to the PCV comes from the work port for that cyl. There may be a small delay before the cyl moves, because it also has to overcome the pressure from the implement if any.
What is the static cracking pressure for your PCV valve?
This valve is a DPOCV from Surplus Hyd
https://www.surpluscenter.com/item.asp?item=9-5606-50&catname=hydraulic
Also click on More Specs
The pilot ratio is 4 : 1
/ DPOCV supplier
The one I've been looking at is 3 bar, or about 43 psi. It has a 1:5 ratio. But I'm not sure exactly how that applies in the actual operation of the valve. Sounds like it means that for instance if my available system pressure is 2200 psi, the check valve would begin to open when pressure from the SCV exceeds 43 psi, and be wide open from 440-2200 psi, begin to close again below 440 psi, and be fully closed again at 43 psi?
Also, I've heard the term "chatter" bandied about in regard to DPOCV's. What causes it, and what's the cure?
And thanks again to you guys for the education. :thumbsup:
