Kubota Hydraulics Question
/ Kubota Hydraulics Question #1
mcd176
Gold Member
Wheeling, WV
Kubota M6800HD / Kubota B2150
I have a Kubota L4200 CUT, My question is this: Does my tractor have "OPEN" or "CLOSED" center hydraulics?
/ Kubota Hydraulics Question #5
Thanks, I was looking into a double selector valve like the link below
https://www.surpluscenter.com/item.asp?item=9-5117&catname=hydraulic
OK, that is what is commonly called a "diverter" valve. Basically it has ONE input and TWO outputs. They are used to "divert" fluid from say the dump/curl cylinders to a grapple on your loader. The 9-5117A is a better one to get because it does not require constant power. Also, the 9-7852 is smaller and $10 cheaper.
Either of these valves won't care if your system is OC or CC, since they are used after the spool valve.
What are you trying to do?
KennyD,
I was looking into using it for my rear remote, I only have one and need two and this looks to be a cheaper option, I looked into the fasse valves and this appears to be the same valve body less the hook-ups, This is a link to what I am talking about: Fasse Hydraulic Valve Multipliers
I do like the valve you gave me the link to for my front end loader because I do plan on adding a grapple in the near future.
/ Kubota Hydraulics Question #7
The Fasse is a good peice, it should include everything you need-but at a higher cost. They only sell through dealers, so you will have to check with yours for pricing.
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
Quick Attach Backing Plate (A65579)
Quick Attach...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
SCAN TO RECEIVE TEXT UPDATES (A65053)
SCAN TO RECEIVE...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
2014 TOP HAT INDUSTRIES TEREX LIVHT TOWER (A65643)
2014 TOP HAT...
