Drill Bit Sharpener?
/ Drill Bit Sharpener? #1
Agrantina
West Tennessee
Kubota L3240 GST
Tired of going thru drill bits left and right is there a good drill bit sharper out there. What about this Drill Dr.? any suggestions
AndyG
/ Drill Bit Sharpener? #2
Do a search on here for a good thread on them. I have the Drill Dr. 750 which sharpens up to a 3/4 inch bit. I love mine...... finally got two full sets of drill bits !
/ Drill Bit Sharpener? #3
I have the Drill Dr that does up to 3/4" bits (750 I think). It works well for larger bits but I haven't had much luck with smaller ones. My take on it is if you have lots of larger bits, over 1/4" and use them on a semi regular basis then it's worth it. If you have a good eye and don't mind them not looking perfect you can use a grinder and save some money.
I have a number of bits that had been sharpened by hand and I just got tired of each time they needed to be touched up I would grind them and each time they would further loose the original shape. When I got the sharpener I spent lots of time getting them back to the correct angle and removing the chips from the cutting edge. Having done that I would suggest it would be better to get the course grinding wheel to get them close.
I have sharpened at least 100 bits and I'm still using the original grinding wheel, a number of them needed a lot of grinding. The biggest problem I had was not tightening the bits tight enough and they would rotate a little in the chuck and instead of sharpening them you would actually grind the edge off the bit making them dull as ****.
Now any time I need to do any drilling I spend a minute or two to touch the bit(s) up. Over all I'm glad I bought it.
/ Drill Bit Sharpener? #4
Drill Doctor here. I LOVE mine. Borrowed my brothers for a couple of months, then, went and bought my own when he took his back.
I have sharpened smaller than 1/4" with no issues.
Deano
/ Drill Bit Sharpener? #5
I use a 1" wide belt sander, doesn't heat the bit like a grindstone! ~~ grnspot110
/ Drill Bit Sharpener? #6
what's the correlation between a drill bit sharpener and Kubota owning & operating? would it not be better placed in a machinist/tool thread? hope you find what you're looking for...drilling into wood or metal? the angles will differ. good luck bb
/ Drill Bit Sharpener? #7
AndyG
I have a Darex I got at auction. Not cheap new but excellent down to small bits.
Rob
/ Drill Bit Sharpener? #8
The holes are going to be drilled in a Kubota
/ Drill Bit Sharpener? #9
I love my drill doctor, granted I prolly do not use it as often now that I have a press, but when I need a sharp bit, it goes to the doc!
/ Drill Bit Sharpener? #10
Rob
Nice find. They look nice in the pictures but I've never seen one and they are way too expensive unless you run a professional service.
It would be nice if we had a dedicated section just for tools on TBN.
/ Drill Bit Sharpener? #11
You can do it by hand on a grinder. I'll admit it takes some practice but between a buddy and my step Dad, they shamed me into figuring it out. I also have the old style sharpener that swings the bit at an angle across the side of a grinder wheel....very basic but very effective. You can put a factory point on a bit every time fairly quickly. I got mine from Harbor Freight but I don't see them on their website now. Sears carries one just like it though. http://www.sears.com/shc/s/p_10153_...alogId=12605&expCheckout=&orderEmail=&langId=
On edit....this got me in the mood so I went out and sharpened some bits. I have to say the by hand/ grinder method does take technique but the sharpener that I posted is super easy and exact...albeit a little crude compared to the power sharpeners. While I was out there my son was working on the metal lathe and needed a bit sharpened to center drill a 2" deep hole in some fairly hard bar stock and the Sears type sharpener produced a perfectly "new" bit in less than 60 seconds start to finish. I gotta say, for a man on a budget, that thing is hard to beat.
Thanks for the replies everyone. Sorry for posting on Kubota ops forum, but its something for the Kubota I thought to put it here? I am lazy and I have made a hitch moving trailers and I needed to drill some exact holes and didn't want to plasma cut them and dang if I could not find a sharp bit out of the entire bunch I had:mad: Want to make an arm to latch the trailer hitch to the ball WITHOUT getting off the tractor:D
AndyG
/ Drill Bit Sharpener? #13
You can do it by hand on a grinder. I'll admit it takes some practice but between a buddy and my step Dad, they shamed me into figuring it out..
I went the same way, got a priced to sell Dr. at Home Depot, but it goes only to 1/2".
Some of my bits are bigger, even 1" and one day I just got pi ...er... excited while drilling something like 3/4" hole in steel and it would not drill. I just took the time and worked it out on a grinder and now I can do them by hand if I have to. Skill is always better than a jig:thumbsup:
/ Drill Bit Sharpener? #14
I'm with ya. I've got this sharpener and it works great!!! My wife bought it for me for Christmas. I must say she did good or was very lucky because she knows nothing about shop tools. ;)
/ Drill Bit Sharpener? #15
I have had a Drill Doctor for several years now. It makes old drill bits new again does a fine job. I wouldn't be with out one. :thumbsup:
/ Drill Bit Sharpener? #16
I've had a Drill Dr. for about five years and wish that I would have had it thirty years ago!
I bought the 3/4 chuck later. I little tip would be to keep the bits "tuned up" right after use. As soon as you give a bit a good workout, hit it with the Dr.
/ Drill Bit Sharpener? #17
Drill Doctor is great as friends give you their old junky drill bits instead of throwing them out.....:thumbsup:
/ Drill Bit Sharpener? #18
Don't forget work. I've just got 3 coffee cans full of bits deemed too dull to use that range from 1/4" to 1". Good old American made ones.
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
INTERNATIONAL 700 SERIES 6 BOTTOM PLOW (A64278)
INTERNATIONAL 700...
2008 JLG 3246ES 32ft Scissor Lift (A64553)
2008 JLG 3246ES...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
12 Ton Hydraulic Bottle Jack (A64557)
12 Ton Hydraulic...
JOHN DEERE 7320 TRACTOR (A64278)
JOHN DEERE 7320...
