deere5105
- Joined
- May 6, 2009
- Messages
- 1,095
- Location
- South Mississippi
- Tractor
- 2008 John Deere 5303 MFWD, 2004 John Deere 5205
I am considering a trailer purchase. I have looked at most every type and am trying to decide on exactly what will best fit my needs. We currently have a 16' 7K with angle iron sides and a 8' 2K trailer for a single four-wheeler.
I am looking for something at least 20' long to be able to handle my JD 5303 MFWD w/FEL and one attachment. The tractor I have estimated at approximately 7300 lbs and my MX6 cutter at 1000 lbs for a total estimated load of 8300 lbs. My current tow vehicle is a F150 that is rated up to 10K. My trips at this time are expected to be 15 to 20 miles each way a couple times a year. I think I have narrowed it to a 20' long 12K trailer to give a little room for more weight if my needs change in the future. I do realize the limitation is the truck, but am not ready to address or change that at this time.
My question is whether to go with a flat equipment trailer with no side rails or something like a utility trailer with the pipe rails? We have an 8' disk that I think would fit on an equipment trailer without rails behind the fenders. Talked to one guy this week that said in those situations he sat his disk on top of the pipe rails on wooden supports. I can see benefits and drawbacks to both types of trailers. For those that have experience with this, what do you have and like or what would you do different if you could. What about the stand up ramps? My tractor and cutter measure 24' from bucket lip to tail wheel. If going 20' it will need to hang off the back some and I can curl the bucket to get further on trailer.
Any advice or suggestion will be appreciated.
