BX25 BH removal/install plus installing 3ph kit
/ BX25 BH removal/install plus installing 3ph kit #21
It took a little while to get the BH & FEL off since it was the first time, but there were no major problems.
/ BX25 BH removal/install plus installing 3ph kit #23
how sad- most of BX25'ers don't even have thier 3pt assembled yet. I use mine all the time. I'd say its the most handiest thing to have.
JT- I say just open the box and try to put it together. I don't think its that hard. I'd do it for you if you weren't so far away. :thumbsup:
/ BX25 BH removal/install plus installing 3ph kit #24
JT, Hope these pics help!
1. Shows 3PH installed on BX25. Note parts in your box!
2. 3PH shown attached to back blade. Key is placement of large metal rod held in place after install by pin and cotter pin. When removed the part with the caution label {Grey} can be placed over the rod after the rod is in place.
3. Rod is held in place by two oblong shaped (note flat sides) inserted into side frame holes with a similar shape. Rod slides through center hole until {Grey} part covers the rod. Key installation step is putting rod in place as shown.
4. This shows view from above including right and left arm connection. Adjustment threaded rods are tightened as required for the attachment being used.
JT, Any questions? Need more pics? Good Luck! :thumbsup:
/ BX25 BH removal/install plus installing 3ph kit #25
Heck, I have a BX23 with 600 plus hours, and I never had the three point hich out of the box yet either.
/ BX25 BH removal/install plus installing 3ph kit #26
I didn't do a triangle but made a simple 2'X4' plywood dolly with six heavy duty 4" swivel casters I got at Home Depot. The BH sat on the dolly lengthwise and was easy to roll around in the garage. It probably takes up more floor space than the triangle one, but was fine for my purposes.
I used 3/4 inch plywood and doubled the thickness so the whole thing was about 1.5 inches thick. Used construction adhesive and screws to glue the two layers together.
Thanks guys for the encouragement, info and pictures.
/ BX25 BH removal/install plus installing 3ph kit #28
Can I ask you BX guys a question: on my B series the 3PH raise and lowers the MMM...which is probably why it was on the tractor when it was delivered. Do you who haven't mounted the 3PH yet have an MMM? If yes, what is the lifting mechanism? Sorry for the dumb question, but curiosity got the better of me....
/ BX25 BH removal/install plus installing 3ph kit #29
On my B, the lift arms that connect to the mower deck and raise and lower it are driven by a linkage that connects back to the lower 3ph arms.
The lift arms that connect to the deck on the BX are connected via their own linkage so they don't require the 3ph to be installed to function.
/ BX25 BH removal/install plus installing 3ph kit #30
fredhardgis-
The BX lift mechanism is done by the top arms that connects to side rods to lower arms. basically the top arms is pushed up by a hydraulic rod.
/ BX25 BH removal/install plus installing 3ph kit #31
So now I'm curious, can you have a MMM mounted on a B with the BH installed (and be able to raise and lower it)? Do the lower lift arms stay on the tractor while the BH is mounted?
/ BX25 BH removal/install plus installing 3ph kit #32
On the B xx20 series, the lower arms must be removed, they're in the way of the backhoe frame....therfore the mower won't raise/lower. I set my mower in the highest position and leave it on. I suppose you could power it an mow at the 4" height, but I won't. Earlier, someone mentioned they made a stub shaft out of another lower arm, and used that for the mower raising/lowering. Clever idea, but I wouldn't want to mow with the BH on anyway, that would be a miserable experience (IMHO). It's my understanding that on the Bxx30 series the arms can stay on...not sure about the mower function.
/ BX25 BH removal/install plus installing 3ph kit #33
Suggestion...
Reference Pic 2 - the pair of rings that secure the through pins, at top.
Don't!
Buy some slip pins / cotters / snap ring pins. I spent more time threading those rings than anything else - also finger risky!
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
Safety Basket Forklift Attachment (A61572)
Safety Basket...
25026SFL (A61569)
25026SFL (A61569)
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
2017 Ford F-550 4x4 Venturo ET25KX 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
Fellabuncher Dangle head, PARTS ONLY (A62679)
Fellabuncher...
