Forks Boy those pallet forks are handy!
   / Boy those pallet forks are handy! #1
Kubota Tee
Gold Member
Hudsonville, MI
Kubota L5740 HSTC-3, Kubota L3540HST-3 (sold)
Ok, here's the background. When we built our house, we designed the garage to double as an indoor sports court for volleyball, basketball, etc. I used fiber-rock on the walls and put heat in the floor for the winter. After searching for several months I finally came across a pair of barely used full size basketball hoops from a Middle School that had closed down. These are the professional kind with 3/4" glass and a full 6 feet across the backboard. I never realized how much these things weighed until I went to pick them up - WOW! ;) I'll bet they are easily 200lbs and then another 15 - 20lbs for the heavy duty break-away rims.
I got them home, unloaded them in the corner of the garage and there they sat for almost a full year! Well . . . I finally got around to buying some heavy duty 2" pipe and flanges to mount them to the wall and after careful measuring I had everything ready to go - at least so I thought. I kept racking my brain on how I would get this very heavy backboard lifted up 10 feet off the ground in such a way that I could bolt it to the pipe flanges. I called several friend who I thought might have a pulley system or hoist that I could borrow - no luck!:mad:
Then, driving home from my son's soccer game it dawned on me that I own a very capable tractor with a very nice set of pallet forks! Problem solved. It did the job with ease! Just don't report me to the OSHA police.:eek:
Next time, I will plan on using the tractor from the beginning!
   / Boy those pallet forks are handy! #2
Those front end loaders are wonderful, aren't they? I've only had my tractor for a month and a half and I've used the FEL for loading supplies in the truck, hauling wood, raising a man high enough to trim a branch off a tree, turning a manure pile and picking apples high up the tree.
I, too, am planning on getting the quick attach pallet forks. They'll be handy for stacking logs and unloading shipments that I have previously had to unload one piece at a time.
I also am planning on reducing my firewood handling by stacking wood on pallets and moving it from woods to shed to outside the house using pallet forks. I just have to come up with a good, easy way to keep the wood on the skids and not fall off when being moved.
I envy your garage, that's really something to play basketball indoors!
   / Boy those pallet forks are handy! #3
I'm not sure how I would have gotten a number of projects accomplished without a set of forks. I think they easily double the value of a loader.
Great looking garage and a good story.
   / Boy those pallet forks are handy! #4
After I got my tractor with a FEL, I couldn't believe I'd "tractored" for over 25 years without one. I still can't figure out how I ever got anything done without a FEL.
   / Boy those pallet forks are handy! #5
Hey, Kubota Tee, from the photo it appears that your QH pallet forks are not locked in!
It is no wonder the safety police are on the lookout for you.:D
   / Boy those pallet forks are handy! #6
That ..... and the absence of even a pallet to stand on ...... :laughing:
   / Boy those pallet forks are handy! #7
My forks are the best $600 I have possibly ever spent.
-Jer.
   / Boy those pallet forks are handy! #8
I've recently bought pallet forks and am amazed at how much I've been able to do. They've really been handy lately for moving small limbs after we had several downed trees from strong winds, in addition to being able to move heavier objects easily.
And I haven't even had the chance yet to pick up some old pallets to set my rotary tiller, rear blade, etc. on to be able to move to clean up the barn or reorganize as I think of better ways to utilize space.
I found a used set of JD forks for my JD 210 FEL that where virtually like new, and gave a litte over $700 including taxes. I had thought about clamp on forks, but am glad these came along. Two pins and I'm hooked up. I normally leave my regular bucket on top of the forks when I'm storing the FEL, so again it saves some storage room.
GGB
   / Boy those pallet forks are handy! #9
Good job. You may want to consider some cross-bracing for the 2" pipe supports in both horizontal and vertical directions. That's a sweet setup for some wintertime ball!
   / Boy those pallet forks are handy! #10
Who makes good, reasonable QA pallet forks?
2010 Toyota Prius Hybrid Hatchback (A53424)
2010 Toyota Prius...
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
Honda EU3000is Gasoline Companion Inverter Generators (A55851)
Honda EU3000is...
1999 MACK RD688S MIXER TRUCK (A55745)
1999 MACK RD688S...
