BH65 Backhoe
/ BH65 Backhoe #1
Doppleganger
Kitchener, Ontario
kubota B2620
Hi All,
I have a B2620 with a number of 3 point attachments (PHD, BB, RFM, SB, etc...). I have decided to buy a BH65 backhoe for it and have come across a good used example. Before I bring it home, I have a question. Will the 4 point mount get in the way of the 3 pt and limit me in any way for the other attachments I use on a regular basis? I don't want to be restricted in any way switching back and fourth between the backhoe and other 3pt attachments.
Any insight is appreciated.
Dan
/ BH65 Backhoe #2
It has not on my 2920...at least not yet with a tiller, grading scraper, and post hole digger...I'll be using a 3PH snowblower later this year and it doesn't seem to interfere with that, either.. It is slightly (and I do mean slightly) inconvenient to remove the hitch to mount the backhoe, but overall not a bad job. My first time was about 45 minutes, but removing the hitch was about 3 of those 45 minutes.
/ BH65 Backhoe #3
hello Dan
I also have a B2620 c/w bh65, I have not experienced any problems between the sub frame mount and 3ph attachments. I use a Back blade, ballast box, RFM, RSB, PHD, Wallenstein wood chipper, bush hog
I would suggest that you have a level area when removing the bh65, this will assist in the reinstalling procedure.
/ BH65 Backhoe
Thanks for the replies fredhargis and canada kubota! Thats great news. Have you both been happy with the performance of the BH65? any shortcomings which I should be aware of? I plan on using it for small projects around the property.
Dan
/ BH65 Backhoe #5
Dan
I have to admit I haven't used mine very much....the BH may truly turn out to be the "toy" in the stuff I bought. That said, the few I have used it (same as you, just small stuff around the property) it has been more than adequate. Consider getting the mechanical thumb as well. I've dug out some out concrete posts and such and it was really a back saver having the thumb.
/ BH65 Backhoe #6
Just a FYI - I have a 16 inch bucket with my BH65 and I feel it matches the B2X20 perfectly. So you may want to seriously consider that in your purchase. I also have a thumb and although its nice I am shocked I havent used it as much.
I have zero problems with any restrictions with the mount however in my estimation the biggest PIA on the on off of the BH is the removal of the 3 pt linkage.
I love my BH - I threw all my shovels away :)
/ BH65 Backhoe
Glad to hear that no one seems to have any regrets with it. The one I am looking at has a 16 inch bucket. Thanks for letting me know it is a good size jambx. I wasn't sure if I would have to downsize to a 12 inch or so. Does the hoe throw the tractor around much or is it a stable when digging?
I plan on getting the thumb but thought I would try it without first and get a feel for it. The thumb looks like it could be very useful.
Dan
/ BH65 Backhoe #8
Doppelganger,
I'm really happy with my BH65 but I wouldn't want to be trying to make money with it.....A great thing to have around the homestead and strong for it's size.....
Easy pull off and on......arms on 3ph takes more time than the BH as others have said.....
I have the mechanical thumb which is good enough for me.....great for logging and small boulders......
I have the 12" bucket but the area I'm in is full of rocks (NH Potatoes) so a larger bucket for BH would be tougher to dig with here .......
Here's some pics of earlier projects.....
/ BH65 Backhoe #9
A couple more....
/ BH65 Backhoe #10
Dan
As for 12 vs 16 - it can go either way. I too have a lot of bones (rock) and hard clay but after using a 12 inch in my BX I decided I wanted to be able to displace more dirt with each grab. I dug a bilco basement door out and the 12 inch bucket felt like it took forever.
As for throwing the tractor around - no and yes. Most BH can do that easily.
I transplanted some blueberry bushes last year - one scoop is all it took! Lots of fun er work. Dug a 400 foot trench 24 inch does (electrical) with ease.
On annoying thing on mine (and others agreed) the BH linkage makes a very wicked rattling sound - I mean really loud. I know of one forum member took his time, took off the control cover and zip tied the entire internals. You would think for the money we pay this would not be a issue. Maybe they corrected it on the newer ones.
Good luck!
/ BH65 Backhoe #11
I have a B21 with a larger more poweful backhoe. Almost all my trenching is in rock, shale or clay. I have a 12" bucket and wish I had a 9". If you are planning to trench in anything hard I would get the smallest bucket you can.
/ BH65 Backhoe #12
I have a BH65 with the 16" bucket and I bought a 10" bucket for the same reason as Bruce. The 10 is much less likely to get stopped.
/ BH65 Backhoe
I like the idea of having two buckets, one for moving volume and one for trenching. I guess I will play.......I mean work with the 16 inch and then see if I should add a 12 or smaller to the collection.
Nice pics wdchyd. Looks like fun. Hopefully I have mine by mid next week. The guy I bought it from is having all the components removed by his dealer and then I am dropping everything off at my dealer to be reinstalled on my tractor. I have 3 or 4 jobs lined up already and can hardly wait till its here.
Question, should the tractor always be lifted off the ground when operating the backhoe or is it stable enough if the wheels are resting on the ground?
I am going to build a large garage. Is it wise to try and dig the frost walls with this unit or should I just hire that work out?
Thanks for all the input.
Dan
/ BH65 Backhoe #14
I leave mine down with Parking brake on....
I'll be digging for my new garage same as you next year....:thumbsup:
/ BH65 Backhoe #15
You will want the wheels (especially rears) off the ground. If they are down and the backhoe picks the tractor up it cant tilt pretty quick.
/ BH65 Backhoe
I picked it up last night and dropped it off at my dealer to be installed. Hopefully everything goes smoothly. I should have it tues of next and will begin digging out stumps right away. Ill post pics next week!
Dan
2011 Black Troxell T120 Vacuum/Water Hauler (A64194)
2011 Black Troxell...
HUSKEE HEAVY DUTY SERIES 42' LAWN SWEEPER (A64278)
HUSKEE HEAVY DUTY...
2018 Ram 2500 4x4 Crew Cab Pickup Truck (A64556)
2018 Ram 2500 4x4...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
UNUSED FUTURE MINI EXCAVATOR RIPPER (A65055)
UNUSED FUTURE MINI...
2021 UTILITY VS2DX 53X102 T/A DRY VAN TRAILER (A67148)
2021 UTILITY VS2DX...
