Tires Really basic BX2230 question: right tire pressure?
/ Really basic BX2230 question: right tire pressure? #1
scobb99
Otsego County, NY
Kubota BX2230, Arctic Cat ATV
Finally got around to prepping my BX2230 for its first working winter here in upstate New York (plan to use the front end loader to move the larger piles of snow that my ATV stacks up).
The tires are bar-type and will try without chains to start but I need to know the right pressures. Front tires had gone flat (I'll be honest, I neglected it this summer due to the day job taking all day, every day, and most evenings too).
Also, seems like the rear tires have liquid sloshing in them. Would they have come from the dealer like that? I bought the tractor in Florida and ran it about 40 hours down there before hauling it up here.
Thanks for any insight...feel a bit guilty that I just bop in here to ask a question then leave. I do have one tip I can share:
When heading out to start your Kubota for the first time after it has sat idle for 6 months, take a can of wasp spray.
Yesterday I found big, active wasp nest under the hood, full of wasps! Fortunately the diesel smoke seemed to keep 'em sleepy long enough for me to go grab the spray.
Stephen
/ Really basic BX2230 question: right tire pressure? #2
First, you are gonna love that tractor!!! I doubt you'll need chains, but who knows. Those bar tires ought to the job!!!
On pressure, you'll get some disagreement, but generally, they work better if you don't over do it. Start with 12 lbs in front and 14-16 in the rear. If you find that too soft, be slow to bump up more than 2 lb increments.
I'd drain the slosh and inspect it. Place the valve in the 6 o clock position and drain out a good three ounces and try and determine what you have. Water? a solution that will freeze? I'd not risk it for a moment. It is supposed to be near 20 degrees here tonight and if you are in upstate NY, your temps will be like that or will be soon enough.
/ Really basic BX2230 question: right tire pressure? #3
Your prepping for colder climate use wouldn't be complete without an oil change to either synthetic 5w-40 Rotella or similar or Rotella10w-30 or Kubota 10w-30.
You know that already, but thought I'd mention it. Also, if you aren't absolutely sure the anti-freeze has been flushed recently, I'd do that too! Cheap insurance and cheap protection. Warning: Anti-freeze must be appropriate for your diesel and off the shelf stuff at car parts and discount stores isn't the right stuff. If in doubt, get it at Kubota.
Fuel filters new? These too will need to be fresh for upcoming winter. Clogged filters can take the joy out of fighting a snow storm in a hurry. Burn up your summer diesel this month, and your local fuel station will be selling you winter blend soon.
Have fun!!!
/ Really basic BX2230 question: right tire pressure? #4
I agree on taking a little bit of fluid out of the rears and see if it has any color to it. if it seems clear, water ? After all it came from florida. I would take the few ounces you took out and stick it in your freezer and leave it overnight. Check it the next day and see if it has frozen. If it did, if I were you- I'd dump the fluid out of your tires in a hurry!!! its getting pretty cold now and you may need to think about adding real liquid ballast in the tires that doesnt freeze so the solution can lower the freeze point whatever water is left.
congrats on your new tractor! :thumbsup:
/ Really basic BX2230 question: right tire pressure? #5
I seem to remember my BX2200 requiring about 25 pounds in the front while doing loader work and a little less when just mowing.
/ Really basic BX2230 question: right tire pressure? #6
I run about 20 lbs or a little more in the front tires, anything less, they squash down a lot with the loader on. I'd take a little bit of fluid out of the rear wheels and if you have any doubt as to what it is, stick it in the freezer and see what happens. You don't want it to freeze.
Wow! Thanks for the all the good [and really quick] advice folks. http://www.tractorbynet.com/forums/images/smilies/2/thumbsup.gif
I love the pure simplicity of "put a sample of the liquid in your freezer".
(I'm embarrassed to say how many years I've spent in cold climates -- including 7 in North Dakota -- without thinking of that method of testing the anti-freeze characteristics of a vehicular liquid.)
New fuel filter, anti-freeze, and oil are now on the checklist.
What about the hydraulic fluid, does that need to be changed?
Thanks...Stephen
/ Really basic BX2230 question: right tire pressure? #8
Thanks...Stephen
Your tractor should have two fuel filters.
I believe hydraulic is changed at 400 hours.
/ Really basic BX2230 question: right tire pressure? #9
Stephen
Do you know the service history of the machine? Look under the tractor. What color filter for the HST do you see? Is it grey or white? While not fool proof, the factory was painted the same color as the frame, dark grey.
If it has been changed, it likely is a light color filter. Did I miss you saying how many hours are on it? If you have 300+ hours on the meter, and you do not know its history, I'd change it, because it is due. If the filter looks new, and it isn't the original painted-in-place filter, it likely got changed at 50 hours.
/ Really basic BX2230 question: right tire pressure? #10
My BX fronts are 22 max PSI. This is fresh on my mind after having just checked them prior to bush hogging yesterday.
/ Really basic BX2230 question: right tire pressure? #11
The front wheels on the earlier BX models were different, "smaller" than the newer ones which have less sidewall height, so the air pressure "may" be different. Of course my memory may be faulty. I have a picture of my BX2200 on another computer if I can find it.
Either way, I don't think the difference is much though.
/ Really basic BX2230 question: right tire pressure? #12
Should be on the side of the tire, right? Scobb99, check the side of the tire...might answer your question. I know my tractor tires have max PSI on the sides, but not sure if that's always the case.
I've seen discussions that more/less pressure is good for certain applications, but I try to keep it pretty close to what the tires say. I've seen some say that with too little pressure, you have the risk of driving right out of your tires when turning. I guess I understand the physics behind that, but no practical experience there.
/ Really basic BX2230 question: right tire pressure? #13
The only times I have had this happen was on the bigger tractors with a load in the FEL or if severely under inflated on a steep slope. I have gotten careless and run both my BX2200 and BX2660 a little under inflated without any problems. The BX models seem to be pretty forgiving on lower than optimum inflation as long as you don't let it get out of hand.
2026 Loadtrail 20ft. 7 Ton T/A Deck Over Flatbed Equipment Trailer (A64194)
2026 Loadtrail...
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
JENDRIX & DIAL UNDERCUTTER, 3PT (A64278)
JENDRIX & DIAL...
2018 CATERPILLAR 320GC EXCAVATOR (A65053)
2018 CATERPILLAR...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
2010 Brenner Aluminum 407 T/A Chemical Tanker Trailer (A64194)
2010 Brenner...
