options for BX2200 front blade
   / options for BX2200 front blade #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
Just got my used BX2200. So far so good. I have the loader valve & 60" MMM.
First attachment I'd like to look into is a power angling front mount blade-something that can push gravel & light piles of dirt around, maybe some snow as well.
What do they cost new from Kubota? Are there other brands that fit?
   / options for BX2200 front blade #2
I think the 60" blade for the Bx series is about $1400 and the sub frame is around $600. I've been looking at the 60" blade for my B3200, and they are about $2600 :confused2:
I've also found that dealers really aren't willing to negotiate much on the price of attachments, not like they would with a tractor. I can't get any dealers to come much below list price.
   / options for BX2200 front blade #4
WOW! Thats ridiculous. :laughing:
Looks like I'll have to keep an eye on CL.
Also look for Deere, Massey and (larger) Cub Cadet plows on CL. It wouldn't be overly difficult to adapt a power angle plow made by one of them to a BX2200. I can send pictures and measurements of the Kubota mounting system for the BX2660 (which is the same IIRC) if you need them.
Aaron Z
   / options for BX2200 front blade #5
Builder, Kubota does offer a 54" lighter duty front blade, which is fine for snow and probably moving loose material. However, it comes with hydraulic lift only, no hydraulic angle. Price is somewhere a bit north of $1K I believe and uses the same quick hitch as the 60" blade and front snowblowers.
I picked up a 54" blade slightly used from Messicks and a new quick hitch, then added the hydraulic angling by having mounting tabs welded to the hitch and plow frame. Cost me around $175 with paying for the welding. If you can weld yourself, you could do it for less. Here's a few pics.
   / options for BX2200 front blade #7
Builder said:
So if I understand you, the 54" blade is light duty non-power angling and the 60" blade is heavy duty and power angling?
Yes, but like I said the 54" is fine for snow and loose material and hydro angling can be added aftermarket. I got the idea from another member here at TBN. Another option would be to buy the quick hitch and adapt a used truck plow blade to fit it.
   / options for BX2200 front blade #8
Last year I think Barlows quoted me 1800.00 for the 60 inch with hitch delivered here to Mass. I would check with them. Also CL in New Hampshire is a good start. Usually some there about this time of year.
   / options for BX2200 front blade #9
Kubota Tractor BX2763 60
$300 less than what i sold mine for last February. These are rare and do NOT depreciate. FWIW
This sounds high, but if gotten for another $100 off, it would be a good buy, believe it or not.
So at $1,500 a good buy?
Massey Ferguson 8200 Flex Platform (A59814)
Massey Ferguson...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
Bear Compound Bow (A57453)
Bear Compound Bow...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
