options for BX2200 front blade
   / options for BX2200 front blade #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
Just got my used BX2200. So far so good. I have the loader valve & 60" MMM.
First attachment I'd like to look into is a power angling front mount blade-something that can push gravel & light piles of dirt around, maybe some snow as well.
What do they cost new from Kubota? Are there other brands that fit?
   / options for BX2200 front blade #2
I think the 60" blade for the Bx series is about $1400 and the sub frame is around $600. I've been looking at the 60" blade for my B3200, and they are about $2600 :confused2:
I've also found that dealers really aren't willing to negotiate much on the price of attachments, not like they would with a tractor. I can't get any dealers to come much below list price.
   / options for BX2200 front blade #4
WOW! Thats ridiculous. :laughing:
Looks like I'll have to keep an eye on CL.
Also look for Deere, Massey and (larger) Cub Cadet plows on CL. It wouldn't be overly difficult to adapt a power angle plow made by one of them to a BX2200. I can send pictures and measurements of the Kubota mounting system for the BX2660 (which is the same IIRC) if you need them.
Aaron Z
   / options for BX2200 front blade #5
Builder, Kubota does offer a 54" lighter duty front blade, which is fine for snow and probably moving loose material. However, it comes with hydraulic lift only, no hydraulic angle. Price is somewhere a bit north of $1K I believe and uses the same quick hitch as the 60" blade and front snowblowers.
I picked up a 54" blade slightly used from Messicks and a new quick hitch, then added the hydraulic angling by having mounting tabs welded to the hitch and plow frame. Cost me around $175 with paying for the welding. If you can weld yourself, you could do it for less. Here's a few pics.
   / options for BX2200 front blade #7
Builder said:
So if I understand you, the 54" blade is light duty non-power angling and the 60" blade is heavy duty and power angling?
Yes, but like I said the 54" is fine for snow and loose material and hydro angling can be added aftermarket. I got the idea from another member here at TBN. Another option would be to buy the quick hitch and adapt a used truck plow blade to fit it.
   / options for BX2200 front blade #8
Last year I think Barlows quoted me 1800.00 for the 60 inch with hitch delivered here to Mass. I would check with them. Also CL in New Hampshire is a good start. Usually some there about this time of year.
   / options for BX2200 front blade #9
Kubota Tractor BX2763 60
$300 less than what i sold mine for last February. These are rare and do NOT depreciate. FWIW
This sounds high, but if gotten for another $100 off, it would be a good buy, believe it or not.
So at $1,500 a good buy?
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
Walk Behind Stripe Machine (A57454)
Walk Behind Stripe...
1991 Snowco Trailer (A59814)
1991 Snowco...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
Truck Mounted Carpet Cleaning Extraction Machine (A57453)
Truck Mounted...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
